Map & Dome Light Upgrades
Old Sep 16, 2009 | 09:12 AM
YellowTA1's Avatar
Default Map & Dome Light Upgrades
Looking to upgrade my map & dome lights. I've seen where people have upgraded these, but I can't seem to find the correct LED size, or how to take the map light apart. Anyone have any pics or info. would be appreciated.
Old Sep 16, 2009 | 12:30 PM
nosaj's Avatar
I used a flat head screwdriver to pop my map lights out. Used 2 13led 194's on maps, cause I wanted them to be bright, they hit the lens but the lens still covers them, you can go with less leds like 5 and they fit just the same. Used a 561 for the dome. Got them off of v-leds.com
Old Sep 16, 2009 | 06:45 PM
thecobrahunter's Avatar
Here a couple pics for my dome light mod:
Just drilled 4 holes, in each of the corners, and installed 4 pre-wired UV LEDs. Tapped into the stock dome light power source.
Old Sep 16, 2009 | 07:53 PM
98 WS6's Avatar
I replaced the map lights with white LEDs, check the bulb type on here or on sylvania.com ..I don't remember. And I replaced the dome light with a festoon-LED bulb.. but any time I would hit bumps it would fall out, and it eventually fried.
I got them from super-bright-led's.
Old Sep 17, 2009 | 12:33 AM
nosaj's Avatar
Yea, it had a different bulb size in the map, but I had a 194 laying around and it fit so thats what size I went with. Some places said it was interchangable with the size that was in there. With my dome, I got one of the festoon bulbs and had to bend where it holds in place to make it stay.
Old Sep 17, 2009 | 12:59 AM
great421's Avatar
Default My "fix"
When I replaced my headliner, I wired in a real 70's style round dome lamp and located it just behind the front seats, powered by the 'rear' dome lamp feed. It looks stock (as it is a GM part) and actually lights up the interior when I turn it on!
Oh, and I put in a 3rd gen rear view mirror too - with switches for the two 'map' lights - that unit works better than my Formula's original lights too!
Just get creative, and make it look (almost) stock - it makes people scratch their heads!
Old Sep 17, 2009 | 07:03 PM
YellowTA1's Avatar
is there a different size in different years? wanting to make sure i get the right ones for my '02 WS6...on sylvania's website, it says all of them are 214-2s....does that sound right?
