grinding brake calipers?
Also be prepared to scratch up the inside of your rims while testing this all out...best thing to do is jack the car up on both sides, then put stands on, then when you are ready to test, put the car in neutral and remove the brake...then turn the wheel w/your hands....you will know if its rubbing...I had to take the wheel off about 10-15 times before it was perfect....it gets pretty frustrating, but stick w/it... <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
