Engine bay
P.S. Car is a '99 and has almost 150k miles on the body.
It's cracked behind the drivers side adjuster. I'll plastic epoxy it and then paint.
I'll look into a DIY method for that. My budget is next to nothing as far as appearance mods go.
Can't do !AIR because the CA referees will be looking at it soon due to a recently completed engine swap. It needs to have all of the emissions equipment installed.
Oh, and thanks.
I am thinking the next appearance thing to do is finish fully polishing the TB and MAF, and also cut out the fin in the MAF housings, grind it down, then polish the inner diameter too (since you can see it with the clear lid). Then get to work on polishing the valve covers... Oh, and the ground wire in the below pic, and the one opposite to it on the drivers side shock tower:
