Re-located fuse boxes?
Old Oct 17, 2009 | 03:34 AM
therealthatguy's Avatar
Default Re-located fuse boxes?
If you have done this I need to see some pics to see where they are being relocated to, i tried it earlier today, and it will be a TIGHT fit if they are going were i think! thanks!
Old Oct 18, 2009 | 02:42 AM
herrrroo?
Old Oct 18, 2009 | 03:01 AM
swaggard's Avatar
i was actually wondering the same thing. so subscribed.
Old Oct 18, 2009 | 09:35 AM
BassProCamaro97's Avatar
Well it's not the stock fuse box but I located my new box to the dash location where the original box was. I'm using a Painless pro street harness so the fuse box isn't much bigger then 6X6.
I don't have any pictures yet.
~Jim~
Old Oct 18, 2009 | 04:59 PM
billyb's Avatar
didn't some one remove the air pump and unbolt the fuse blocks the ones under the hood then slip them down where the air pump was ??? it took themout of view from the hood area.
Old Oct 18, 2009 | 06:12 PM
swaggard's Avatar
https://ls1tech.com/forums/10021340-post7.html
This is the only thing i could find
Old Oct 18, 2009 | 06:39 PM
DCC!!'s Avatar
they have to go in that little square hole right underneath where ther are factory.
you can only do it if you AIR system is deleted tho. its really hard to fit them threw that hole but its posable i did it on trans am and my freinds camaro lol
just make a cover for it and it loooks WAYYYY better!
Old Oct 18, 2009 | 09:07 PM
LS1Fury!'s Avatar
I believe that guy had problems with the box getting wet and had to relocate again
 Michael S. Palmer
Old Oct 18, 2009 | 10:05 PM
DCC!!'s Avatar
damnnn did he really??? what happend when they get wet??
Old Oct 18, 2009 | 10:07 PM
swaggard's Avatar
i believe he said that he pulled the relays out, blew it out with an air compressor, and let it dry out. if i'm not mistaken
Old Oct 19, 2009 | 01:34 AM
Disturbed Bird's Avatar
just put them in a zip lock bag and then zip tie the bag so they cant get wet
Old Oct 19, 2009 | 05:00 PM
billyb's Avatar
^^^ good idea.
Old Oct 19, 2009 | 05:23 PM
Scira's Avatar
j/k....but there must be a better way to keep them dry. A good idea would be to find where the water is coming in and close that part off with something.....
Old Oct 19, 2009 | 09:02 PM
DCC!!'s Avatar
Thats is a good idea! and i wouldnt totaly seal it off you might have to get to it later....
Old Oct 19, 2009 | 09:56 PM
ls2 bait's Avatar
car is driven in the rain weekly and washed twice a week, have never had an issue. just tug on the harness a bit and they will fit. i cut the hole larger so they are easier to move if need be. (hasnt been needed in 2 yrs+)
and dont bust my ***** car was dirty as hell when i did it.
Old Oct 20, 2009 | 01:21 AM
thanks for the pics ls2bait!! these pics have motivated me to just cut it and make a cover for it.
Old Oct 20, 2009 | 01:31 AM
swaggard's Avatar
yeah thats nice placement
Old Oct 20, 2009 | 06:56 AM
Jeff Smith's Avatar
GD Idea..SubScribing.
Old Oct 20, 2009 | 02:10 PM
ramairracer's Avatar
someone needs to make a template for the cover and id be all over this
Old Oct 20, 2009 | 08:37 PM
hell yes! Specialized Stainless should make a cover for that area after the fuse boxes have been re-located, as well as were the battery use to be...
