Headlight removal
Al
Installation if the reverse. The headlights come out easier than they go in, because you wind up sort of fighting the black gasket thingy.
Hope that helps.
Dan
<strong>Be sure to tape off the painted part right under the headlight. You might scratch it trying to get the headlights out. Trust me, I know. I just pulled mine out 3 or 4 days ago to install clear corners. I didn't tape anything off and I paid the price.
Dan</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorry to hear that Dan, I guess you didn't see the post ( link above ) that I replied to a few weeks ago. Another good idea is to wear Mechanix Wear glove's, there can be some sharp edges on the headlight assembly and surrounding area.
<strong>Kevin, I'm not sure what you mean by "headlight buckets" unless that means where the headlights sit. If you're just looking on how to remove the headlight assembly this post might help https://ls1tech.com/ubb/ultimatebb.p...=002164#000003 , I find it much easier to pull out the fascia when removing the headlights. I hope this helps some but if not I'm sure someone will come along with the right answer, good luck.
Al</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Great write up Al,
Here it is in full:
Here's how I've done them in the past.
1. Remove the five black push-in pins from the top of the fasica. This will allow you to pull the fascia out while sliding the headlight assembly towards the center of the car. By pulling out the fascia it will give you that needed extra room to pull the headlight out, I remove the headlight at a slight angle.
<img src="http://groups.msn.com/_Secure/0MgCdFFkRxaXjd8RfLVcO6w!Qee02lhdzGQjyMH2RW6Ihj083l x9EiRyFt33vSyFHA1ZUz7tqV5dxbmFfwXOAdg/C5.jpg" alt=" - " />
2. Remove the 10mm bolt from the back of the headlight, no other bolt should be removed to take the headlight assembly out.
<img src="http://groups.msn.com/_Secure/0MgB0cFcRZ6V5fuxtaNMIu04SNU9eLxrN4B2wtdW41uz0kYZOZ 06dq4NObgIRjLx1k2HDLBy1ybjRVl962oa3SQ/C3.jpg" alt=" - " />
3. I like to use masking or duct tape EXCELLENT ADVICE!!! on the fascia around the headlight area, this will help protect the paint on the fasia. Looking at the back of the headlight you'll notice two tabs, when re-installing the headlight make sure you slide the two tabs in the proper area. The blue tape shows the tabs.
<img src="http://groups.msn.com/_Secure/0MgAAAFgRlqXKw*BI*WuVNI6CHFLHWhkq0q7joVWifqKrspVZq hUAn7nVu7rnlHOAIi*TTMhjXEdZkJ4OIDCo8Q/C4.jpg" alt=" - " />
One thing I forgot to mention is you need to disconnect or remove the headlight bulbs before you pull the headlight assembly out, if you remove the bulbs do not touch the bulb with your fingers.
Thanks again AL!!!!!
It looks great. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Thanks for the tips guys!
Joe, I wonder how you guessed it was Teds car. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Kevin, glad to hear it worked out for you, I still would suggest the use of tape on the fascia to anyone planning on doing this.
Al
<strong>Kevin, glad to hear it worked out for you, I still would suggest the use of tape on the fascia to anyone planning on doing this.
Al</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree. Better to be safe than sorry.
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by camaro_ls1:
Dan</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sorry to hear that Dan, I guess you didn't see the post ( link above ) that I replied to a few weeks ago. Another good idea is to wear Mechanix Wear glove's, there can be some sharp edges on the headlight assembly and surrounding area.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks for the concern. No problem though. They were minor scratches and I was able to buff them out...fortunately.
