Undercoating Will it hurt the Value?
my carfax does state that in september 2002 when the car was in for service that these things were done
Vehicle serviced
Paint sealant/undercoating installed
ABS system checked
Cooling system checked
Rear brakes replaced
Drive belts checked
I don't know if that just means it got a wax job or if the dealership did actually undercoat the car.
incidently, i've seen a lot of 4th gens with paint missing in the wheelwells and/or an undercoating on half of the wheelwell lip. mine does not have this.
this is what i'm talking about. notice how my car has full paint there. on some fbodies the inner portion of the lip down by the ground effects has no paint or has been painted over with something else. you can see a little bit of my undercoating in the wheel well in the pic, but what i'm talking about is ive seen that stuff sprayed on part of that large black inner fender lip just in front of the tire.
I took that pic after using touch up paint to fix a few chips on the lip to prevent corrosion from starting. even though i don't drive my car in th winter i don't like to have exposed bare metal.
also feeliing around behind that little wheel well lip i found a few places where there were little pieces of something stuck to the wheelwell. almost like dried bits of something like rustproofing that maybe spotted up in one place or another. whatever it was it wouldn't budge. i tried to see if it was dirt or something and tried to pick it off and it was bonded in there tight.
This is the passenger side
and this is the drivers side.
that is right at the middle of the top of the wheel well btw. You can see the rustproofing i was talking about earlier in the wheel wells
