Removing decals...?
Old Aug 20, 2002 | 01:59 PM
Obi-Wan B.O.B.'s Avatar
Default Removing decals...?
I'm looking for some advice on how to remove the original decals from the center piece between the tail lights of my 99 TA. Does anyone have any experience doing this? What's the best and safest way to do it without damaging anything? I tried using a razor blade after wetting the area, but that seems like a lot of work and it was leaving some scratches.
Any help would be greatly appreciated. Thanks a lot.
Bob
Old Aug 20, 2002 | 02:12 PM
MONGOOS's Avatar
Default Re: Removing decals...?
that's not a decal between the taillights... it's paint. Unless someone put a decal over it to change the color??? If that's the case then heat it up with a hair dryer and pick at the edge with your finger nail.
Old Aug 20, 2002 | 02:17 PM
unit213's Avatar
Administrator
I'd like to know also. I'm going to replace my stock z28 decals. I'm pretty sure a blow dryer and dental floss is the way to go. Hot water should loosen them up too.
I've never done this before, but there's no way in hell I'd come within ten feet of my paint with a razor blade.
Old Aug 20, 2002 | 02:35 PM
Xsta Z 28's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by camaro_ls1:
<strong>. . . I'm pretty sure a blow dryer and dental floss is the way to go. . . .</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">YEP. That works. The use Goo Gone to remove any remaining sticky stuff.
As for the TA Firechicken on the tail panel, that takes much more work. You effectively need to wet sand and buff that sucker off.
Old Aug 20, 2002 | 08:52 PM
GREEN GOBLIN's Avatar
You can go to the dealer and get one for either a 95' or 96' T/A and it bolts in where that one does, it's solid black, but the price is about $100. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
