front panel moved
Old Dec 16, 2003 | 03:07 PM
stocksleeper02's Avatar
Default front panel moved
i have an 02 z and the driver side front quater panel looks like it moved and now theres a gap between the door i havent hit anything at all but it's like maybe a half inch gap can anyone tell me why it did that
Old Dec 16, 2003 | 03:17 PM
Scooter's Avatar
By quarter panel I assume you mean fender. Is the pass side off or just the d/s. On the inside of the fender is there any signs of the fender moving(scratches around bolts that hold fenders) Are there any other gaps that appear off?
Old Dec 16, 2003 | 03:30 PM
yea the fender is fine theres no scratches or anything so i dont know there no visable reason as to why it moved it just did
Old Dec 16, 2003 | 04:17 PM
travisnd's Avatar
was you car jacked up recently?
Old Dec 16, 2003 | 08:03 PM
Cokeroker's Avatar
Default fix action
it happens when someone manually jacks up the camaros. If they do not put the jack deep enough under the car it hits the fender/frame attach bolts and warps this small piece of metal which will cause the fenders to bow out and cause that gap. It is actually pretty easily fixed by getting under the car and bending that metal piece back in place. From now on, you should baby your baby and make sure anyone doing anything on your car knows better... it happens a lot!
Old Dec 16, 2003 | 08:11 PM
craiG's SS's Avatar
U said it was the quarter panel, well since there is no way that the bolts could be loose or anything, b/c quarter panels are welded in, fenders are bolted in, just like someone else said it could had been the way it was jacked up, if the car is a t-top car or if u jacked it up near the middle and open the doors while it was jacked up it might had bowed the car a little! u cant open the doors or pull the t-tops out if u hav the car jacked up in the middle or u have done some damage
