Seatbelt bracket on headrest
Old Dec 29, 2009 | 05:51 PM
ghardester's Avatar
Default Seatbelt bracket on headrest
So today I got out of my '02 WS6 and bumped into the bracket on the side of the headrest that guides the shoulder/seatbelt. Just went 'tink', and broke.
So can I just buy the plastic bracket? Probably not as the seat belt goes through it. Do I have to buy the whole seatbelt assembly for that side?
I'm trying to keep the car mostly original and having a part broken kind of freaks me out. What do I need to buy and where?
Old Dec 29, 2009 | 08:02 PM
homerunhtr21's Avatar
That piece is 7 dollars from gm. And are easy to break with any pressure.
Old Dec 29, 2009 | 08:05 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
You should be able to get one. To replace it, you need to unbolt the seatbelt which attatches with a t-60 bolt if memory serves me correctly.
Old Dec 29, 2009 | 09:05 PM
peterlawl84's Avatar
I did the same thing last year, tried driving without it but it got annoying. Eventually, I got a replacement from gmpartsdirect, wasn't too expensive, but the shipping costed more than the part. You can buy the guide by itself.
Old Dec 29, 2009 | 10:20 PM
TempleU_WS6's Avatar
I remember seeing one that a guy made out of metal that actually ran the belt at a lower angle. Wish someone or a company would jump in and start making them. I'd replace my plastic ones even though they're not broken.
Old Dec 30, 2009 | 04:51 PM
ghardester's Avatar
Thank you all for your input. I found and ordered the part.
Old Dec 31, 2009 | 02:03 AM
HWI's Avatar
HWI
I'm almost 100% sure it's a T-50.
Old Dec 31, 2009 | 12:22 PM
PontiacFan's Avatar
You can also buy the ones used on the convertibles, which have an opening slot to insert the belt, ..., & not have to mess with the bolt.
Old Jan 1, 2010 | 11:11 PM
Torque Fiend's Avatar
6le sells a leather strap that will most likely work on the factory seats.
It's 30bux though, but looks better than the plastic thing sticking out.
Old Jan 2, 2010 | 05:12 AM
6LITEREATER's Avatar
Yeah, it EASILY mounts in place of factory guides (you just screw it in with the factory screws)...
I was going to mention it in here then I saw the OP wanted to keep it as factory as possible... Thanks though for spreading the gospel Torque Fiend
Old Jan 2, 2010 | 06:52 AM
99FormulaM6's Avatar
I just went to the dealer a few weeks ago and bought one. I bought the convertable one though because I wanted the opening in it. I think all total it was around 10-15 bucks. Plus with the vert one, you don't have to take off the seat belt, simply put this one on and you can cut the broken one off
Old Jan 2, 2010 | 08:18 AM
Cheetoh's Avatar
Anybody have the part number for the Convertible Seatbelt loop?
Old Jan 2, 2010 | 08:36 AM
https://ls1tech.com/forums/3064669-post24.html
Old Jan 2, 2010 | 10:32 AM
bobodog's Avatar
yea the same thing happened to me. i got one from gm but i cut a opening in it w/ a saw and sanded it. works good and u cant hardly see it
Old Jan 2, 2010 | 03:53 PM
Seems like that would take more time than just taking the one bolt out and slipping it through
Old Jan 2, 2010 | 07:23 PM
Clark Kent's Avatar
I had a friend here in san antonio that made his out of metal. He made a mold and had chrome ones on his car. Never heard from him again after i bought his tru duals. looked good and was sturdy.
Old Oct 27, 2014 | 04:02 PM
ragtop69's Avatar
Kinda makes you wonder why GM didn't cast those stupid guides in a more flexible plastic compound that would have been harder to snap off. Mine broke because my fat a$$ pushed against in when trying to enter the car in a tight parking space. After that I super glued it and it broke over and over again. I'm waiting for USPS to deliver a new one from Rick's Camaro. Base price was $20, but it cost $28 with shipping and CA sales tax.
Old Nov 1, 2014 | 03:06 AM
vikingramair's Avatar
Or change to 6LE design,
