Fog light replacement
Old Jan 7, 2010 | 01:46 PM
thecobrahunter's Avatar
Default Fog light replacement
Ok, what is the easiest way to remove the fog lights on a '95 Camaro? Looks like I have to put the car up on jacks to get underneath the car's front fascia! On my '98, just had to take out the headlights, and bam!! Direct access!
Old Jan 8, 2010 | 02:28 AM
Also, how the heck do you remove the center console top, pass the shift **** on an automatic???!!!
Old Jan 8, 2010 | 04:31 AM
Ls1CamaroGuy87's Avatar
Turn the key to "on" and put it in first gear. Then just pull it off, it takes a tiny bit of maneuvering
Old Jan 8, 2010 | 03:16 PM
Okay, just in case I'm being a total knuckle-head, the thin opening for the console is supposed to somehow get past that big shift **** without breaking/cracking. But what about that sliding thing? It only has a small hole that the shift shaft comes through?
Old Jan 8, 2010 | 03:32 PM
^^haha no sir. You take the shift **** off. Look at the front of it, there is a small horse shoe-shaped pin holding it on there. Remove that with a small flathead screwdriver and then just pull the shift **** off...
Old Apr 21, 2010 | 02:41 PM
K, so now that I;m back to this little project now...how do you replace the fog light bulbs on a 97 Camaro? Looks like I gotta remove the whole front bumper fascia to get to them.
Old Apr 21, 2010 | 03:33 PM
bill12690's Avatar
to be honest i dont even remember from back when i had my 97, but this should help..
http://www.bfranker.badz28.com/fbody/fogs.htm
