Removing Molding
Old Aug 29, 2002 | 02:17 PM
Bionik's Avatar
Default Removing Molding
I need to know what is the best method for removing the molding on the doors of my trans am? Also what is the best way to remove the adhesive after i remove the molding? Thanks
Old Aug 29, 2002 | 05:44 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
Default Re: Removing Molding
I haven't taken mine off yet, but I think all you need to do is take out the push tacks that are in the wheel wells. Then there are just bolts underneath the car that go down. It shouldn't take more than 2 hours for both sides. Most of that will probably be cleaning up the goo. I would say use some goo gone. That stuff works like a charm. That's what I'll be doing anyways. Anyone else who has already completed it care to chime in?
Old Aug 29, 2002 | 05:52 PM
MONGOOS's Avatar
Uhh... there's nothing in the wheel wells holding the molding on.
get a hair dryer and some fishing line or dental floss... heat the front edge a little and work the string of choice behind the molding... then peel it back with your finger tips GENTLY. keep heating and peeling all the way down the line till you're done... get off any excess goo you can by hand, then hit it with some goo gone or bug and tar remover. Took me about 2 hours o do the whole car, take your time.
Old Aug 29, 2002 | 06:02 PM
phil46y's Avatar
One more thing that will work great for removing the adhesive is WD-40.
Old Aug 29, 2002 | 07:01 PM
Joe "Preachers Sheets" DIESO's Avatar
Humanitarian
Just like Phil and Mongoose said. Heat the area with a hair dryer, peel off badge, peel off glue then use some WD-40 to remove glue residue. Follow up with a mild polish to remove any swirls and make the newly exposed area blend with the surronding panel.
Old Aug 29, 2002 | 07:53 PM
supersp0rt's Avatar
the best way not to do it: when the car is cold...also do not spend 3 hours removing the tape by hand...youll get blisters on you fingers...lots.
Old Aug 29, 2002 | 08:06 PM
VSGLS1's Avatar
Anyone have any pics? My friend is taking his off when he repiants his car...it look better with out them IMO.
Old Aug 29, 2002 | 08:07 PM
LS1Baron's Avatar
Remember to listen to this board. Use a hair dryer, and patience. I'm not a patient person, so I thought a heat gun would do it quicker. There is now a REASON why you won't see any pix of my poor, suffering baby yet.
 Michael S. Palmer
Old Aug 29, 2002 | 09:14 PM
Bionik's Avatar
Oh man i am pissed, i just removed some of the molding and it looks like the paint has actually been damaged by the molding <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> . Looks like they somehow scratched the paint. Maybe i can buff it out with some rubbing compound.
Old Aug 29, 2002 | 10:59 PM
Bionik's Avatar
Well i just got done with the drivers side and it turns out that it was only the piece between the two air vents that had damaged paint, the rest was fixed with some polish. It looks really nice <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> . I haven't removed the trans am logos yet. would that look even better, or should they stay? <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Old Aug 30, 2002 | 02:45 PM
BMW ///M Nerd
huh, for some reason when I lookedn at it last it looked like there was a push tack in each wheel well. I've been trying to decide if the trans am on the door would look better there or off. I have the silver "trans am" emblems I was going to put on but I don't know if I even want it on there.
