SS Hood ~ Grille Removal
Old Sep 1, 2002 | 07:41 PM
KevinL's Avatar
Default SS Hood ~ Grille Removal
Just wondering if someone could tell me the best way to remove the small plastic grille in the SS hood. I need to remove it so it can be painted.
Thanks. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
<small>[ September 01, 2002, 07:44 PM: Message edited by: KevinL ]</small>
Old Sep 1, 2002 | 10:06 PM
DaddySS's Avatar
Default Re: SS Hood ~ Grille Removal
I've read that you take a small screwdriver and carefully get in behind it and with slight pressure it should pop out.
Old Sep 3, 2002 | 09:31 AM
Xsta Z 28's Avatar
If you look at it real close you'll see there are four clips top and bottom of the grille, VERY CAREFULLY take a tiny flat blade screw driver and pry up ever so slightly the tabs along the bottom and the grille will come out.
Old Sep 5, 2002 | 07:13 PM
FlagSStaff's Avatar
I used my pocket knife and it took me less than 30 seconds to get it out.
