need more appearance mods...
Old Feb 12, 2010 | 01:51 AM
  #41
DCC!!'s Avatar
GRill and then just make your own coil relocation! i did it its easy! its like 20 bucks from home depot and then u gota get wires. so both lol!!!
Old Feb 12, 2010 | 01:55 AM
  #42
brian_rs/ss's Avatar
sweet....u got pics or a materials list? or both?
Old Feb 12, 2010 | 09:40 AM
  #43
CHRIZ28's Avatar
Lol, definatly do something with that grille. I just pulled mine out, and had the holes filled. But even just removed without em filled looks 10x's better than a crappy stocker... On the antenna deal, just cut it off and find a rubber cap to put on it. Had mine like that for like 5 years. There's alot of little cheap things you can do to make it look "cleaner". The molding doesn't seem like alot, but when they're gone you'll notice how much better it looks. Plus its way easier to wax lol.
Chris
Old Feb 12, 2010 | 09:50 AM
  #44
Juicy J's Avatar
Coil relocation would be a good idea. It would not only look good, but would make it alot easier to do simple jobs like changing your spark plugs.
Old Feb 12, 2010 | 10:05 AM
  #45
slow96z's Avatar
What I did wan twist off the metal ball at the end and cut the antenna on my grinder with a slight taper on the tip, then pressed the ball back on for a more factory look. Plus that way you don't have to try to find a rubber cap.
Old Feb 12, 2010 | 11:11 AM
  #46
CHRIZ28's Avatar
I tried that, but we couldn't for the life of us get it to come off. Just said hell with it and cut it off lol. It does look better with the ball put back on though. The coil relocation is a good idea too, I really like how the stock valve covers looked all polished up. Might have to do this to the Hawk. EDIT: Wonder if you could grind off the mounting stubs for the coil brackets?
Chris
Old Feb 12, 2010 | 02:05 PM
  #47
DCC!!'s Avatar
yeah il try to get some pics later on today
all you need is some flat sheet metal that will hold it i used 18 gauge i think?cant remember lol
then i used a 1/4 inch all thread and a lot of nuts! like the whole box of them lol then just drill your holes and space them right anbd mount them!
Chris
you can do that also!
all you have to do is grind them off and jb weld the hole they leave if your gona paint them but if you gona polish then you have to get them welded the right way lol
Old Feb 12, 2010 | 03:38 PM
  #48
hmmm i like the idea of polished vc's but i hate the mounting holes, i wonder if u grind them down real carefully and just leave the holes there if it would look ok?
Old Feb 12, 2010 | 05:41 PM
  #49
DCC!!'s Avatar
like leave the mounting tabs on with it polshed?
Old Feb 12, 2010 | 06:44 PM
  #50
caseypryan's Avatar
Here's a picture of my factory antenna cut. It's about 8 inches long I just took bolt cutters and cut it, then sanded the tip round then painted it black again and it looks perfect and very good. Very easy to do and looks great.
Also I vote a billet SS grille with SS in the center like the ones from 6LE.. I used to want the SLP grille but they are expensive then I got this one to tide me over and now I like it better. Here's a picture of mine on (you've probably seen them 100x already):
Old Feb 12, 2010 | 06:53 PM
  #51
i want the blue bowtie one. i dont think a white ss badge goes with the rest of my car.
Old Feb 12, 2010 | 06:54 PM
  #52
well grinding them down nice and smooth like, with out filling them with a weld and then polishing them. cuz...i has no welder....
Old Feb 12, 2010 | 07:01 PM
  #53
caseypryan's Avatar
Yeah the blue one is cool too..but I just don't like the idea of having blue on a car that has nothing else blue on it. Quick question, did you get your car tuned after the cam swap?
Old Feb 12, 2010 | 07:04 PM
  #54
yes i did. its pretty healthy, thanks to g-force
ok pewter camaro. blue bowtie:
and i'm pretty sure i'm gonna have some type of chrome rim. ether zr1's or TT's.
Old Feb 12, 2010 | 07:10 PM
  #55
caseypryan's Avatar
Yeah it sounds very very healthy and sounds amazing I'm considering putting that cam in my car. What kind of power do you make?
And the bow tie looks good..but the blue just looks off IMO and if you have and SS I think you should brag about it
Old Feb 12, 2010 | 07:11 PM
  #56
caseypryan's Avatar
Oh and the TT's on the pewter camaro next to it look SICK. Rims will be a night and day difference
Old Feb 12, 2010 | 07:17 PM
  #57
also TT's on a pewter SS.
Old Feb 12, 2010 | 07:40 PM
  #58
caseypryan's Avatar
Very good numers. I'm wanting to hit 400 rwhp so maybe after LT ORY LS6 intake and a 228 or the 224 I'll hit it. Great numbers though. Sorry to hijack, back to appearance!
Old Feb 12, 2010 | 08:18 PM
  #59
DCC!!'s Avatar
well im not sure bc i havnt done it yet but im pretty sure when you grind them down to be smooth it leaves a hole there? but you could get it welded at a fab shop or somthing but i have no idea how much it would be lol
Old Feb 13, 2010 | 08:19 AM
  #60
legendarysouls's Avatar
Blacked out nose emblem
