- Camaro 2010 – 2015: How to Replace Tail Light <br>Step by step instructions for do-it-yourself repairs.
Tail light dimple fix attempt
I'm going to use resin to "fill" the dimples, sand it down so it's smooth and even, and then do a light coat or two of vht and I'm betting if it works, you won't be able to tell there were dimples in the first place. The resin should dry clear, but won't really matter anyways with the vht.
I'll post pics up when I start working on them.
Thoughts and ideas are welcome!
REMEMBER that as long as you have stock style filament bulbs in ls1 tail lights they risk being warped due to the heat that they emit...
If you want to ensure that they dont warp then you need to switch to led or preferably SMD bulbs like I did.
i tried (and failed horribly) to fix them another way that someone mentioned in that same thread. i wont go into that though... im still a tad bit mad i ruined a light
good luck with it. post up the results, even if you fail, just so we know it doesn't work, so no one else repeats it.
but anyways, FAIL.
the dimples are not at all pleasing on the eye, and anyone who has them know's how annoying they are
