60mm Gauges+vents=???
Old Feb 25, 2010 | 09:58 AM
ninjai_ruken's Avatar
Default 60mm Gauges+vents=???
What do you guys think it would take to get a 60mm gauge to fit in our vents? It seems as if its just a tad to small. And I am not sure a vent ring would work. If so, it would be a small *** ring.
2 5/8 Gauge = 2.62 And it fits nice and snug
2 1/16 Gauge = 2.06 Needs Vent Rings
60mm Gauge = 2.36 hmmmmmm
EDIT: So looking at a pic of some 60mm Gauges and they have it labeled as 60mm/2.6 How can that be? Or am I just that bad at my math?
Old Feb 25, 2010 | 10:09 AM
whitdog54's Avatar
I believe someone made them work using rubber fittings in the vent. I actually had the part number for home depot for it, but I just changed phones.
Old Feb 25, 2010 | 10:26 AM
Yeah, that works for the 2 1/16 gauge. I wonder if they have a rubber fitting that would work for the 60mm gauge...damn European made Gauges
Old Feb 25, 2010 | 11:18 AM
Spd-Kilz's Avatar
I think your math might be off:
2 5/8" = 66.67mm
2 1/16" = 52.39mm
2.36" = 60mm
I have 2 5/8 and they are not super sung. It's going to take a thick bead of silicone to keep them from falling out. You'll definitely need an adapter if you use the 60mm gauges.
Old Feb 25, 2010 | 11:19 AM
Spd-Kilz's Avatar
ACTUALLY, if you keep the vent ring in, it might not be too bad!
2 5/8" are loose if the vent ring is out.
Old Feb 25, 2010 | 12:44 PM
hmm, I might have to see what I can come up with
By Brett Foote | 2026-06-04 05:00:17
