Racing Seats and weight
Old Feb 25, 2010 | 07:16 PM
joblo1978's Avatar
Default Racing Seats and weight
I've been looking for some seats to cut down on the weight.
Some Corbeau CR1's would be nice, but a pair weighs as much as the stock TA seats.
I'm not hardcore enough for aluminum Kirkey's.
Anyone know of a seat that is significantly lighter and still adjustable?
Old Feb 26, 2010 | 02:49 PM
brian_rs/ss's Avatar
not really. most adj seats are still about 30-35lbs per seat.
Old Feb 26, 2010 | 04:23 PM
SIK02SS's Avatar
Ya, you really get limited when you still want adjustable. I don't know the weight of Bride seats but maybe look into those.
Racing seats, are always fixed back and average right around 20-25lbs unless you spend closer to 3k and get the lightweight versions that are in the 15lbs range. So how important is the weight thing to you?
Old Feb 26, 2010 | 04:34 PM
if u r really looking to shed weight:
https://ls1tech.com/forums/drag-raci...y-updated.html
Old Feb 26, 2010 | 07:00 PM
joblo1978's Avatar
After some more research I found out that the CR1's are 27 lbs. with their brackets even in wide widths. Not sure if this is cloth, suede, or leather though.
That's fairly significant over the power TA seats according to the weight list. I think I'll just go with those then.
Old Feb 26, 2010 | 07:04 PM
joblo1978's Avatar
Ya know, I've been using that and shed quite a bit already.
My next task is installing some lightweight carpet for the vert without the rubber backing and oziting the gas tank hump. Stuff is on the way.
Hopefully this, firewall insulation, the backseats, belts and brackets, CR1's, and a grant steering wheel will give me 100 lbs. back.
