keyed
Old Sep 25, 2002 | 08:45 PM
PurpleZ's Avatar
Default keyed
My car was recently keyed by some jelous highschool kids. It is not too bad but what can I do to cover up the scratches?
Old Sep 25, 2002 | 08:55 PM
Ep_camaro's Avatar
Default Re: keyed
get a new paint job
Old Sep 25, 2002 | 08:58 PM
770Guy's Avatar
Default Re: keyed
Burn it and collect the insurance money.
Old Sep 26, 2002 | 12:22 AM
Bad 00 SS's Avatar
Default Re: keyed
u need to find out who it is and beat the living fuc$ out of that person, omg, I fuc#kin hate punks, I hope they burn...I'm 17 and own a 00 SS and I have never messed with ne ones car, I hope u find those mother fuc#ers and take care of that shi# real quick
Old Sep 26, 2002 | 07:46 AM
unit213's Avatar
Administrator
Default Re: keyed
I feel your pain. I have a key scrach starting in the middle of my passenger door ending over my rear passenger wheel. I'm getting it fixed soon.
Old Sep 26, 2002 | 07:48 AM
unit213's Avatar
Administrator
Default Re: keyed
There are two simple rules to follow in life:
1. Don't f*ck with a man's woman.
2. Don't f*ck with a man's car.
The order is sometimes open for debate. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Sep 26, 2002 | 11:48 AM
DARK AGE 53's Avatar
Default Re: keyed
I'll try to explain a method that has worked for me on the past, you'll need these items.
1. 3M Finesse-it II finishing material.
2. 1500 grit wet sanding disks.
3. Sanding spool.
4. 1/4" pinstriping tape.
5. Spray bottle with water and a touch of dish soap in it.
6. Touch-up paint ( I'm guessing purple in your case.
7. Clear touch-up paint.
Place the tape as close to the edge of the scratch as you can without covering the scratch itself. Take you touch-up paint and apply a thin coat of color, just enough to cover the scratch, remove tape. I like to let the paint dry over night even thu you could do it sooner, place the tape now about an 1/8" or closer to where you have repaired the scratch. Put two thin coats ( allow 20 minutes between coats ) of clear over the repaired area, remove tape once you put on the last coat of clear. Let the paint dry over night, take the sanding spool with a 1500 sanding disk and wet it down with the spray bottle. Spray the scratch with the water bottle, lightly sand the repaired area in the same direction as the scratch. While your sanding keep spraying that area, change the disk when ever you think it has built up paint on it. Only sand until you have the clear flush with the rest of the cars paint ( wipe dry ever so often to check how you're doing ), a point here, do not sand any farther out then the repaired area. Use the 3M Finesse-it to polish out the painted repair.
I would suggest you try this method someplace like under the hood to make sure you're comfortable with doing this.
You should be able to find these items at your local auto paint supply store, I've enclosed a few pictures to give you an idea of what I'm talking about. Good luck.
Al
Sorry for the poor picture, the tape is wider then 1/4" in the picture.
<img src="http://groups.msn.com/_Secure/0NAAAAGQRMaste3VbrvR6nX5Y7G6kC1BApMkb4oxGo9dKH0045 8X02*qPXJgtJ*hRZ**7Ruecx765YnYPvDqFyg/P102.JPG" alt=" - " />
<img src="http://groups.msn.com/_Secure/0NAAhAmMRAqsU8n4POmZSWnagv4!8qTiHc*3XjuVIWV9kbP4UM s2AVsrych0YKDrFNc7BeGb4heuZHnlcf4FIpQ/P101.JPG" alt=" - " />
