Powering up a cluster that is not installed?
Old Mar 18, 2010 | 12:41 PM
madhatter's Avatar
Default Powering up a cluster that is not installed?
I picked up a 01 WS6 roller last week. The wiring was stripped from the car. I am parting it out and people are asking about the mileage. Is there a way to power the cluster without it being in the vehicle so I can see mileage? The wiring schematic I have shows grounds at pins B11 and B15. It shows switched ignition voltage at pic A3 and battery voltage at pin A10. I have tried to supply the power and grounds but it still does not light up. Any ideas?
Thanks
Sean
Old Mar 18, 2010 | 03:57 PM
DaddySS's Avatar
I believe it has to be connected to the BCM - if you look in the wiring for the cluster the odometer and warning lights are listed as "serial data".
