rail covers
P/N 12559261 (LH)
P/N 12556455 (RH)
These can be had for about 30 bucks apiece (discounted) from SDPC (one of our sponsors)
The LH cover (drivers side) will not need to be modified
The RH cover (pass side) will need to be modified ... You can do a search here on LS1Tech to find out what needs to be cut on the pass. side cover.
Ron,
Make sure you run a search looking for FRC's. There are a lot of helpful threads on this topic. Feel free to PM me if necessary when installing them. Oh ya, make sure you have a dremel if you do install them. Keep it on a lower RPM setting or you'll melt the plastic instead of cut it.
Dan
<small>[ October 22, 2002, 11:44 AM: Message edited by: camaro_ls1 ]</small>
