Disabling fogs with HID's?
Old May 6, 2010 | 12:56 AM
feelnlo's Avatar
Some great info here!
Question:
"...the fog light wire coming from the headlight control block..."
Might be a dumb question but where exactly do I look to locate this and do u know what color wire?
Old May 6, 2010 | 10:34 AM
Nova5's Avatar
Its where you have the headlight control ****. thats the block I speak off. You'd need to pull its trim ring and unmount it. Then do the same to the foglight switch. identify the foglight wire by using a volt meter or tracking the wire physically from one end to the other.
Old May 6, 2010 | 06:04 PM
staticx57's Avatar
You can turn the fogs on by moving the **** to the parking light position which will turn on the back lights the console lights and the fogs.
If you use HIDs in your fogs remember to turn off the fog light switch before you lock your door so the dont flash on when you lock/unlock..
