Leaking T-top
Old Oct 28, 2002 | 10:47 PM
Black Death TA's Avatar
Default Leaking T-top
I'm not sure if this is the right area to post this in, but it is the only place i thought it would make sense in. I drive a 2001 T/A with T-tops (obviously), and during rain, about an inch after the ttop joins to the windshield pillar above the driver side window water will seep in. Not alot, mind you, but it drips enough to be very annoying at a stoplight. I have to constantly reach up and wipe away the drips <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" /> ! Has anyone had this problem? Or could it be my ttops arent on good enough?
Old Oct 29, 2002 | 12:08 AM
Quickin's Avatar
Default Re: Leaking T-top
You need to adjust your T-Top a little forward, that should do it.
Old Oct 29, 2002 | 12:24 AM
2002_TAWS6's Avatar
I had the same problem and moving it out helped solving it.
Old Oct 29, 2002 | 02:29 PM
SILVER BULLET's Avatar
I had a similar problem and had the dealership check it out and they took care of it under warranty
Old Oct 29, 2002 | 02:44 PM
arcom's Avatar
So how does onw adjust the T-tops?
