DDM HID - doesn't always fire up every time?
Old Aug 31, 2010 | 04:54 AM
ChvyCruzen's Avatar
Default DDM HID - doesn't always fire up every time?
This is odd, sometimes my DDM HID low beam don't always fire up. One will fire but the other will not. This seems to happen every other week? Anyone know the cause of this I wonder if it means I need a relay...
Old Aug 31, 2010 | 09:38 AM
92SilverSHO's Avatar
yeah you need a relay. I have the same problem, so i bought one but i have to put it on.
Old Aug 31, 2010 | 09:08 PM
Ruthless909's Avatar
^^^ What he said
http://cgi.ebay.com/ebaymotors/9005-...Q5fAccessories
Recently installed one myself.
Old Aug 31, 2010 | 10:04 PM
djfury05's Avatar
I have one.. 2 actually.. but I left them off because I have no idea how to wire them! How in the hell do you wire it? My DDM lows ballast on driver side quit because of not having a relay
Old Aug 31, 2010 | 11:08 PM
The red wire with the fuse(#3/#7)goes to the positive side of the battery.
The black wire(#4) should be grounded to the chassis.
Basically, the male plugs(#1 and #2) from the harness is the power plug that will feed power to the ballasts.
However, you should have only one female plug(#5). That female plug has to be plugged into the passenger stock light harness.
Old Aug 31, 2010 | 11:12 PM
Link I pasted on previous post is the exact same relay harness I used and is the one pictured above.
Install is so easy even a caveman can do it.
Old Sep 1, 2010 | 05:06 AM
evilZO6's Avatar
i have the same problem on my E36. You either need a power relay harness as pictured above, or you have a bad ballast. I had a bad ballast. Change your ballasts from one side to the other and see if the problem follows one of them. If that doesnt work then try your bulbs.
Old Sep 1, 2010 | 08:22 AM
ChvyCruzen's Avatar
I said in my OP that this only happens once every other week or so. My ballasts and bulbs are fine - for now.
Do I need 1 relay or two? It looks like I only need one. After examining the relay, how do the headlights know when to turn on if the only power supply is straight from the battery? There's no input switch that tells the relay to start drawing power? Like an 85/86/87/87a/30 relay.
Old Sep 1, 2010 | 01:56 PM
batmangixxer's Avatar
oh i ordered that from ddm when i bought my kits (the dual in dual out wire harness) but i never used it cuz i didnt know how to install it so basically i can f**k up my wiring and lights if i dont use the relay wire?
Old Sep 1, 2010 | 03:31 PM
ChvyCruzen's Avatar
It is my understanding (based on info shared via ls1tech and my engineering background) that the HID ballasts have a high draw upon start up (cold fire up). After they run for a little while, they warm up and do not have such a high draw anymore ... So it is during these start up periods they need more draw than the stock harness can provide ... even though stock is 55W and you have a 55W HID, that is the draw when the HID's are warmed up.
Someone said that you can lose a ballast by not running the relay if you're having problems. I guess that really could go either way, depends on design and components used. I intend to run a relay just so I can have my headlights every time. I could wire in an 85/86/87/87a/30 relay rated for 40 AMPS for cheap but the relay harness in ebay is like $8.50 shipped...
Old Sep 1, 2010 | 03:35 PM
ChvyCruzen's Avatar
Basically, the female plugs(#1 and #2) from the harness is the power plug that will feed power to the ballasts.
However, you should have only one male plug(#5). That male plug has to be plugged into the passenger side.
Your terminology here threw me off. I believe plugs #1 & #2 are male and plug #5 is female. The #5 female plug goes into the passenger stock light harness - this is what tells the relay to turn on and off.
Thanks!!
Old Sep 1, 2010 | 06:43 PM
Better now?
I was tired and falling asleep when I wrote it, brah.
Old Sep 1, 2010 | 07:07 PM
Thanks!!
so did u guys cut your stock wires --or do these work straight from the battery
Old Sep 1, 2010 | 07:18 PM
No cutting
Everything is plug in play
Old Sep 1, 2010 | 07:27 PM
No cutting
how do u figure none of those sockets will fit into my sockets (halogens) i got just two metal prongs in them with a wire feeding to the ballast
Old Sep 1, 2010 | 07:29 PM
if u have a trans am i think this is what u need to fit into the socket
http://cgi.ebay.com/ebaymotors/H7-HI...Q5fAccessories
Old Sep 2, 2010 | 04:45 AM
ChvyCruzen's Avatar
Better now?
It was bugging me, I was trying to figure out how the relay would know to turn on and provide power to the ballasts ... A good write-up, regardless of the little typo
Old Sep 3, 2010 | 12:58 AM
My bad....
Thanks!!!!
Old Sep 3, 2010 | 02:15 PM
Post a picture of the relay harness.
Old Sep 3, 2010 | 03:58 PM
i already did mine--i bought the dual in dual out wire from ddm and i cut the plastic so i could make my relay harness plug and play
