Who makes brighter headlights??
If you have a Camaro and wish all four lamps on with highbeams, then go to my website. At the bottom of the 1st page, I have a table contents that will tell you which page to go to for a free mod to do what you want.
I also have a mod to allow the foglamps to run when the high beams are on if you like. Again, a super easy and free mod.
This foglamp mod works on the Pontiacs too from what I understand, but the wire colors might be slightly different. The principle is the same though and it should be easy to figure out.
The foglamps on with the high beams are nice because the foglamps send a 'glow' into the ditches right the critters eyes can be seen, giving them away and allowing you a little warning before they jump out. It helps out here in the cornfields of MN anyway...
Good luck
Dave
