Trufiber WS6 install....
Old Sep 18, 2010 | 09:15 PM
Chaos07's Avatar
Default Trufiber WS6 install....
Well i got my hood and test fitted and evrything is good except one thing....when i try to put the hinges i can only get the bolt closes to the strut in n tight but i cant even get the other farther away started at all there are 2 rivets in between the 2 holes how do i solve this?
Old Sep 18, 2010 | 10:01 PM
Chaos07's Avatar
come on guys i know there's people out there who have a WS6 trufiber hood help me out
Old Sep 18, 2010 | 10:05 PM
evelluser's Avatar
Is it possible to drill holes in the hinges? Or possibly get hinges from a WS6 on here being parted out
Old Sep 18, 2010 | 10:08 PM
Chaos07's Avatar
thats no the problem the rivets almost make it impossible to get the bolt in, but i can get the one closet to the strut in just not the other one fartherest from the strut
Old Sep 18, 2010 | 10:15 PM
Chaos07's Avatar
[IMG][/IMG]
Old Sep 18, 2010 | 11:40 PM
evelluser's Avatar
i would suggest either getting a dremel with a sanding wheel, and sand down the areas a little bit, where the rivets hit it. or possibly drill holes large enough in the hinge plate over the rivets that the rivets will not be bothered by it
Old Sep 18, 2010 | 11:50 PM
Chaos07's Avatar
good idea well i have to go to fastenal to get one of those bolts cuz one fell down into the engine, so if i can get one a little bit longer ill do that if not then ill modify the hinge plate like u said. ive emailed tru fiber to see what i could do
Old Sep 18, 2010 | 11:58 PM
evelluser's Avatar
ooooo... that sucks. no magnets around or anything? good luck though. keep it updated lemme know how it works. and be careful not to take too much off, or you could risk ruining the structural integrity of the plate, and then it would be wasted effort
Old Sep 19, 2010 | 12:05 AM
Chaos07's Avatar
yup it fell but i have no idea where 2, i have a magnet ill fish around for it soon..
Old Sep 19, 2010 | 02:58 AM
meine96ws6's Avatar
Make small openings in the bracket for the hoods high spots.. It's less of a risk then doing the hood.. I imagine the latches are cheaper also..
Old Sep 19, 2010 | 09:47 PM
9WhiteCamaro9's Avatar
i think theres a video on youtube that shows how to install an aftermarket hood but idk what brand hood it was to know weather or not they would have kinda the same setup or not as far as where the hinges mount to
Old Sep 19, 2010 | 10:08 PM
67goatman455's Avatar
what about drilling out the rivets, counter sinking the holes and put new rivets in? of course you would want to thread your bolts in first so the plate doesn't fall down into the hood
Old Sep 20, 2010 | 02:59 AM
hitmanws6's Avatar
id call trufiber, ive never seen these rivets before, on mine or anyone elses. mine took 20 minutes to install
