Products to use with Buffer
Old Oct 11, 2010 | 05:50 AM
mook99ta's Avatar
Default Products to use with Buffer
Just got a new Porter Cable buffer and will be using it for the first time on my white TA. What compounds and polishes are best for getting rid of swirl marks and slight scratches and then what do I use to give that deep shine back?
Old Oct 11, 2010 | 08:40 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Read this.
http://www.meguiarsonline.com/forums...ad.php?t=38239
Then you should have your answer. Also you need some good lighting to help inspect for results. You do not want to use the strongest pads, strongest chemicals, and putting pressure on the buffer first. Start with less and work up.
Old Oct 11, 2010 | 08:45 AM
99zee's Avatar
M105/M205 combo with the Orange Lake County pad has worked well for me. Follow that with a quality polish/wax with the white or grey pad.
Old Oct 11, 2010 | 04:42 PM
Raven02TA's Avatar
no better combination than that right there.
Old Oct 11, 2010 | 04:48 PM
homerunhtr21's Avatar
You might check out the Cyan pad to replace the Orange pad also. But m105/m205 is awesome for 90% of most basic corrections.
Old Oct 14, 2010 | 06:27 AM
mook99ta's Avatar
Thanks guys!
