Backlighting in the speedo
Old Jan 1, 2003 | 11:19 PM
Red Dragon's Avatar
Default Backlighting in the speedo
Is the backlighting on the dash of the TA red cause of the overlay or is it a red bulb.
I was wanting a different color and was hoping it was bulb not the overlay
thanks
Old Jan 1, 2003 | 11:35 PM
Fbody Man's Avatar
Default Re: Backlighting in the speedo
when i put my white face gauges in my camaro the bulbs in the cluster were regular white the t/a should be the same.
Old Jan 2, 2003 | 08:20 AM
Xsta Z 28's Avatar
The color is by the overlay.
Old Jan 2, 2003 | 03:00 PM
Red Dragon's Avatar
is there anyway to change the overlay over to a clear one???
Old Jan 6, 2003 | 10:41 AM
CMNTMXR57's Avatar
For the gauges it's the overlay. These are translucent displays.
If you pull the instrument cluster out of each car, pop them apart and pull off the face look at the back and you'll see the Chevy has plain white and the Pontiac has "warm red".
There are other bulbs in other areas that Pontiac's specifically have little red bulbs that are only available at the dealer (at least that's the only place I can find them) but otherwise, all use a clear/white 194 or 189 bulb for lighting.
Old Jan 7, 2003 | 10:09 AM
30th TA 0219's Avatar
Don't mean to hijack, but what if you wanted to get rid of all the red?! lights above door hadles, TCS, etc? Get ASR, radio, and steering wheel controls from a Camaro!?!
