15x10 DragLite spacers?
Old Jan 6, 2003 | 09:48 AM
PlowTown Missile's Avatar
Default 15x10 DragLite spacers?
I'm putting 15x10 DragLites on the back of my '99 Z28. With no spacers they are hitting the snubbers over the rear axle tubes. Anyone know what thickness the spacers need to be?
Old Jan 6, 2003 | 10:04 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: 15x10 DragLite spacers?
5/16" spacer, and they shouldn't be hitting the snubbers unless you have the car jacked up and the axle is hanging all the way down. Try putting the jack under the axle itself.
-Tony
Old Jan 6, 2003 | 10:19 AM
Yup, I had the car jacked up by the body. Tony, do you know what the ARP part number is for the longer studs that I'll need?
Old Jan 6, 2003 | 10:50 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Sorry, no idea on that. I used the stock studs when I had a stock rearend, it worked fine. With the 12-bolt, I ordered the longer 1/2" studs with it.
Stock studs are 12mm x 1.5 if that helps.
-Tony
Old Jan 6, 2003 | 11:32 AM
thanx, Tony. I'm about to leave to go buy my studs and spacers. Are you sure "5/16 are wide enough? Just making sure. I have 265/50R15 Radial T/A's on the rims. The snubbers were hitting the sidewall of the tire when I jacked it up from the side.
