Removing Paint From Caliper
Old Oct 30, 2010 | 02:04 PM
TurdsOfMayhem's Avatar
Default Removing Paint From Caliper
The hawk I bought has the rear calipers painted. How do I go about removing it? I don't want to remove the caliber to do so, as I haven't done that before.
Brake cleaner and a small wire brush?
Old Oct 30, 2010 | 02:45 PM
ssteven's Avatar
My 95 Z28 had spray painted calipers. I used scrub brushes, wire brushes and sand paper to rough and clean up the surface. I didnt fully remove all the spray paint. But I painted over it with a G2 paint kit and never had probelms for years(no flacking , peeling etc)
Old Oct 31, 2010 | 06:47 PM
I would like to completely remove it if not as much as possible. Have no interest in re-painting them
Old Oct 31, 2010 | 07:05 PM
Smoke Em's Avatar
try carb cleaner or lacquer thinner
Old Oct 31, 2010 | 07:14 PM
jb98camaro's Avatar
using any substances that remove paint will damage rubber and plastic parts so avoid getting any on your caliper piston boots and brake lines..
good luck man!
Old Nov 1, 2010 | 12:58 AM
9WhiteCamaro9's Avatar
^ Thats what I was about to say lol. But to the OP, I'd either water sand em, use paint thinner (but cover up all parts like hoses and anything that could get damaged), or take em somewhere and have em blasted with something that the paint shop would recommend.
Old Nov 1, 2010 | 01:40 AM
Super-Bat's Avatar
Brake fluid will take the paint right off.
Or gasoline.
