moisture in drivers side backup light on trans am
Old Nov 8, 2010 | 06:48 PM
mushroom281's Avatar
Default moisture in drivers side backup light on trans am
Is their an easy fix? I haven't taken my tail light out yet but was wondering how you guys fixed it if you had that problem
Old Nov 8, 2010 | 08:02 PM
I was wondering if those lights would come out. Or how they come apart before I terms into them
Old Nov 8, 2010 | 08:56 PM
Swiat34's Avatar
The outer lens is one piece. Take your light out and set it in the sun for a few hours to let the water evaporate out. When it's gone run a bead of silicone or model cement (not krazy glue) on the top lip of the lense. I'm talking about the corner of that lip that the lens makes by sticking up past the top of the black housing. Also check the rubber gaskets on the bulb sockets.
Old Nov 9, 2010 | 01:26 AM
9WhiteCamaro9's Avatar
What Swiat34 said cause I may be wrong but I think the T/A's tailights were kinda like "soldered" together or atleast melted to together in certain spots. And OP you aint to far from me.
Old Nov 9, 2010 | 08:07 AM
Sweet thanks. And white Camaro I was down your way a week or so ago I went to Robbins for some parts
