da** T/A headlights
Old Nov 26, 2010 | 11:26 PM
gopherit98's Avatar
Default da** T/A headlights
does anyone have problems with their headlights hitting everything? i can adjust hood, covers try to slide whole assortment to the side, and it will work for about a month, and start doing something new? i tighten the crap outta everything the whole problem happened after aftermarket hood. I'm getting pissed because the fog lights are only bright enough through the highways and i live on country roads so HID's just aren't putting out enough light and it sucks to raise the hood put lights up the shut it.
I'm thinking of slotting brackets, but before i do anyone else have this problem?
Old Nov 27, 2010 | 02:04 AM
doomsdaymachine's Avatar
i was having problem that my lights would get stuck, all because the hood need it sum alignment. then that got fix and the problem was that since my wires had a bit of corrosion that was taking power away for one of the lights to open, i replace that with new wiring and now works good.
Old Dec 4, 2010 | 11:02 PM
gopherit98's Avatar
my lights hit the hood and i slotted it all the way back any furth it hit the cowl. i pushed brackets opened then started hitting fender lip moved other way hit hood again lol
