Need a trunk panel
Old Dec 10, 2010 | 08:38 AM
nichoLaS1's Avatar
Default Need a trunk panel
Is there somewhere I can get a panel to cover up the area in the trunk where a stealth sub-box/ disc changer would go (driver side cubby). I hate having a big empty space there and I think it'd help quiet the interior a little if I could install a panel w/ some insulation.. Needs to be ebony btw
Old Dec 10, 2010 | 01:34 PM
Rubrburnr's Avatar
Not that I have seen. I posted a little while ago that I would start making them but there wasn't enough interest... even found a place where the material was a pretty close match to the trunk material. Here are a couple pics of the first I did. In these pictures the material I used is close but not compared to where I found the new material at...
Attached Thumbnails Need a trunk panel-f-body-trunk-panel-1.jpg   Need a trunk panel-f-body-trunk-panel-2.jpg
Old Dec 10, 2010 | 01:39 PM
nichoLaS1's Avatar
is that just a flat panel, or does it have some depth to it (similar to a sub box)..
Old Dec 10, 2010 | 01:59 PM
Rubrburnr's Avatar
No, it's just a flat piece. If you need some more insulation to help with sound, I would just get a bunch of foam padding (rolled/stuffed) to put behind it. I don't know how much that would help with noise though from that space but when you do, let us know...
Old Dec 10, 2010 | 02:02 PM
nichoLaS1's Avatar
Alright thanks, looks like I have another project to do
Old Dec 10, 2010 | 04:36 PM
ssjason232's Avatar
is this what you need?
[IMG][/IMG]
Its in perfect shape, white things in pic are just pieces of the packing peanuts i had blowing around.
If so, i have one sitting in my garage. PM me if you need it.
Old Dec 10, 2010 | 04:37 PM
ssjason232's Avatar
If you need more pics, i can send those too.
