Trans Am Fog Lights
Old Jan 18, 2011 | 11:28 PM
my bandit's Avatar
Default Trans Am Fog Lights
anyone think to try these as a replacement or do you think they are too big?
it is 5.75" round (isnt factory 4.5?) and it takes an H4 bulb
http://www.ddmtuning.com/Products/5-...nd-halogenLamp
Old Jan 18, 2011 | 11:40 PM
chon79's Avatar
Nice find, would love to find some nice replacements to avoid the melting OEM foglights from my HIDs.
Old Jan 19, 2011 | 01:45 AM
FQZ's Avatar
FQZ
Great find I'm in desperate need of some fog lights. Mine are missing
Old Jan 19, 2011 | 11:32 AM
my bandit's Avatar
im not sure if they will fit or not though
Old Jan 19, 2011 | 11:50 AM
SparkyJJO's Avatar
Tape measure is your friend
Old Jan 19, 2011 | 12:57 PM
chon79's Avatar
hey bandit, I am at work right now. take some measurements and see if they would fit
Old Jan 19, 2011 | 05:32 PM
my bandit's Avatar
alright well the stock fogs are 4.5" the opening (measured from the front of the bumper) is just over 5.75" the only problem would be making the bracket to mount them up. anything will fit the only question is will it look good. it seems like these are headlights so they might put out a good deal of light too
Old Jan 19, 2011 | 07:05 PM
SparkyJJO's Avatar
More light isn't a bad thing if aimed properly, especially since the birds have the craptastic sealed beams.
I'm not familiar with how the stock ones mount but I'm sure there would be a way to fab something up
Old Jan 19, 2011 | 07:11 PM
Irish350's Avatar
if memory serves the mounts are a weird setup.. the bottom has a mounting point (hinge sorta) and the top has that single 'adjustement' screw... meaning if you make your own bracket it needs to be a better design, or needs to be aligned properly since youve only got up/down per GM
Old Jan 19, 2011 | 07:25 PM
FQZ's Avatar
FQZ
I might experiment with these . I don't have the brackets either
Old Jan 19, 2011 | 11:43 PM
99'CajunFirehawk157's Avatar
Junkyard, heard earlier pontiacs had glass foglights...fwiw.
Old Jan 20, 2011 | 12:02 AM
PUNISHER TA's Avatar
I heard this also. that the LT1 birds had glass lenses.
Old Jan 20, 2011 | 01:28 PM
f-body.cbct's Avatar
I want new ones. My passenger one went out so I just turned them off.
