Firebird Light Bulb Question?
Old Jan 21, 2011 | 02:08 AM
SpeedFreak123's Avatar
Default Firebird Light Bulb Question?
I have a 96 Firebird, and my rear side marker on the driver side is out and doesnt light up red anymore, Obviously, LOL.
I was wondering if any one knows the bulb size for that side marker (Rear), I had planned on getting one tomorrow.
Old Jan 21, 2011 | 02:52 AM
Super-Bat's Avatar
#194 bulbs.
If the connector is bad, here's a write up on how to replace:
http://www.fbodyonline.com/rear-side...nector-how-to/
Old Jan 21, 2011 | 07:37 AM
DopeFedZ's Avatar
1996 PONTIAC Firebird
High & low beam headlamp
H4666
H4666ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H4666XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
H4666CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
3057
3057ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3057LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front turn signal
3057
Rear turn signal
2057
2057ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
2057LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
2057
3057
Stop light
2057
3057
High mount stop light
921
921ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
921LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Fog/Driving light
880
880ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
License plate
194
Back up light
1156
1156ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
1156LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Front sidemarker
194
Rear sidemarker
194
Ash tray
194
Glove box
194
Map light
212-2
212-2LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
906
906LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Step/Courtesy light
194
562
562LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
74
74LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Trunk/Cargo area
562
Instrument-general
161
161LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
37
37LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
73
73LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
PC74
Check engine indicator
PC74
Hi-beam indicator
PC74
Seat belt indicator
PC74
Brake warning
PC74
Automatic transmission indicator
73
Directional signal indicator
161
Old Jan 21, 2011 | 01:39 PM
ZexGX's Avatar
Superman is correct. It is a #194.
Also,
^ that huge Sylvania bulb list is wrong on so many items, yet PEOPLE STILL REPOST IT.
If you're going to repost it, at least make sure the info is correct!
For example, all of these are WRONG:
Rear turn signal
2057
Tail light
2057
Stop light
2057
Back up light
1156
Dome light and Map light are switched around. The Map light is the dome light and the dome light is the map light.
