gto seats to camaro
Old Jan 21, 2011 | 11:34 AM
2000z28camaro's Avatar
Default gto seats to camaro
i'm looking at putting some 04-06 gto seats in my 00 z28, anyone else do this or know what all i would need to do to be able to do this, any help would be great thanks!
Old Jan 21, 2011 | 11:40 AM
qwikz28's Avatar
Use a search. It's more than possible, it's been done. I have a set of GTO seats in my garage that I will be shoehorning into my Camaro this winter.
If you are tall, it won't work. They sit higher. What I am trying to do to remedy that is to use universal sliders instead of the power motor, and eliminate that, and run only the power motor for the recliner. Hopefully, that will allow it to sit lower. If you want, PM me in a few months and I'll give you an update.
Old Jan 21, 2011 | 11:45 AM
nope not tall so it'll be all good, yea the power motor is what is holding me up causr i don't know much about electrical, but i could just hook up the seats and bypass the power seats basically?
Old Jan 21, 2011 | 12:51 PM
GoFast908Z's Avatar
Have you searched yet?
If you don't hook up the power, you'll never be able to move them.
Old Jan 21, 2011 | 01:10 PM
99FormulaM6r's Avatar
I've seen a pic a while back....they look out of place in an fbody IMO....Just looks way to big with respect to the car.
Old Jan 21, 2011 | 01:35 PM
omarrakeen's Avatar
why are you doing it? more comfort or looks? if your looking for more comfortable seats id recommend redoing yours..good luck.
Old Jan 21, 2011 | 02:16 PM
Trans Am Jam's Avatar
I simply typed "GTO seat in camaro" in google search.....2 seconds later..
http://www.cardomain.com/ride/228131...-camaro/page-2
Old Jan 21, 2011 | 05:51 PM
qwikz28's Avatar
If you have the seats, you will notice that there will be one connector that should connect to the car. That connector will have three wires. You will only need to connect two of them. The red to 12 volt and the black to ground. The seats will then work in all positions. You will then be able to run move your seat as well.
Old Jan 21, 2011 | 08:01 PM
Cheap Guy's Avatar
After looking at the pics, I'd have to agree. The 6Litereater seats look like a better match.
Now if someone GAVE me a set of GTO seats...
Old Jan 21, 2011 | 08:11 PM
Buffalo's Avatar
I'm six feet tall. Is that too tall? I'm thinking of doing this also.
Old Jan 21, 2011 | 08:40 PM
Empatho's Avatar
Is this a direct bolt on installation?...I did see that part of a bracket needs to be cut, but is there any other modifications needed?
quote from the cardomain page
I would say the limit is about 6' 2", which would put your head right near the roof
Old Jan 21, 2011 | 08:51 PM
qwikz28's Avatar
As posted above, it will fit, but its close. It depends on personal taste. I'm 5'9" with proportionately short legs. Where I'm at now in my car, I can just see over the cowl hood. The seating is low, but I love it. Everything is better lowered. Cars, seats, even school buses.
See?
Old Jan 21, 2011 | 11:08 PM
Cheap Guy's Avatar
While looking at the GTO seats on eBay, I saw the Cobalt SS seats. They look like they'd fit better and are cheaper. Did a search and it seems like they're a decent seat.
Old Jan 22, 2011 | 07:59 AM
qwikz28's Avatar
make sure they are the recaros!
Old Jan 22, 2011 | 11:26 AM
just get corbeau cr1s ....honestly those are probably only like $200 off from what you are going to spend and they will be a hellluva lot better.
