How do u clean burnt rubber
Old Jan 23, 2011 | 12:49 PM
camaroboy14's Avatar
Default How do u clean burnt rubber
How do I clean the burnt rubber from my rear panel?? I went to the track and of coarse I heated up the tires and afther when I got home I saw alot of black tire/rubber on my rear fender I guess(right where the tire ends). I just want to know how to clean it off....
Old Jan 23, 2011 | 12:55 PM
egott_91's Avatar
A good washing. If everything doesn't come off, clay bar or bug and tar remover.
Old Jan 23, 2011 | 01:16 PM
Sweet ...any brands?? Or is anythinh fine
Old Jan 23, 2011 | 01:44 PM
Smoke Em's Avatar
ive always had good luck with tar remover, it takes a little bit but it comes off without harming the paint
Old Jan 23, 2011 | 02:41 PM
94 Camaro Z28's Avatar
Next time mask of the rear bumper with painters tape. easy to remove and won't mess the paint up or leave residue.
Old Jan 23, 2011 | 02:53 PM
boostednismo's Avatar
WD-40 will work.
Before the track spray Pam or some nonstick cooking spray on the panels and it will come off a lot easier.
Old Jan 23, 2011 | 04:20 PM
Stangkilr's Avatar
I like the orange de-greaser stuff. It works the best IMO.
Old Jan 23, 2011 | 04:30 PM
2001-CamaroSS-LS1's Avatar
all of the above...and/or a power washer...works like a champ! i never used any cleaner...i just used my power washer and it came off...but...painters tape does work better then all
 Michael S. Palmer
Old Jan 26, 2011 | 12:30 AM
Ls1dreamin02's Avatar
Before you go wipe a thin layer of vaseline on the area. That will do the trick. When you get home just wipe it off and wash. Works like a charm.
Old Jan 26, 2011 | 09:05 AM
meine96ws6's Avatar
Great idea...
Old Jan 26, 2011 | 09:43 AM
chon79's Avatar
Wash and claybar the rest is what I do.
Old Jan 26, 2011 | 09:56 AM
TWS's Avatar
TWS
I often wash the car the night before going to the track and put a heavy coat of wax on the quarter panels/wheel well lips and don't wipe it off. This helps keep the rubber from adhering. Then bug and tar remover afterwards.
I am actually going to the track tonight and put painters tape on the rear wheelwell openings and quarters this time.
I have used WD40 in the past and it makes such a nasty greasy mess when taking the rubber off that I had to throw away the wash mitt I was using. I prefer the "wax before/bug and tar remover after" technique.
Old Jul 10, 2015 | 03:07 PM
Cilajet's Avatar
Default Never worry about burnt rubber damaging paint again!
Hey there ~ Check out www.Cilajet.com and www.cilajetreviews.com to learn how you can easily and permanently protect your race car from burnt rubber on your fender and side panels after a fun day at the track.
Cilajet is an Aviation Grade (Boeing approved) auto paint protection that is only applied at auto dealerships. Cilajet is not like a traditional "auto paint sealant" wax or other coating commonly made available to consumers via detail facilities, paint and body shops or retail stores.
When you apply Cilajet to your vehicle the burnt rubber will not stick to your paint AND your vehicle will always have a mirror like finish that will make your race car sparkle and shine on and off the track!
Old Jul 10, 2015 | 04:53 PM
RAMPANT's Avatar
Best I have used is Joe Gibbs Foaming Degreaser. Works extremely well. I found it when looking into oils, and noticed it mentioned used by the Nascar team remove rubber. Ordered a can it has been the best degreasers and rubber removers I have tried.
Called Driven Speed Clean now.
http://www.drivenracingoil.com/dro/s...ean-15866html/
I am sure several vendors on here sell it.
Old Jul 10, 2015 | 04:55 PM
HISS's Avatar
Charcoal lighter fluid. Rinse well after. Won't hurt the paint.
Old Jul 13, 2015 | 11:17 AM
NightHawwk's Avatar
I know this is a little off subject but I got a huge patch of spent tire in my wheel well after dropping it off at the mechanic's shop for one night. Can't trust anyone these days. In any case this thread was helpful, thanks.
Old Jul 13, 2015 | 12:09 PM
01ssreda4's Avatar
Wd40 for me.
