Damn You Grant!!!!
http://www.summitracing.com/parts/GRT-61040/?rtype=10
I can tell you , that all you would need to do to use the grant wheel in that link you posted, is to swap the smaller metric upper steering shaft from a late model W body , 01-03 or 04-08 Grand Prix or 06-current Impala . The grant wheel in the link you posted goes in the current Impala/DTS/Lucerne along with all the trucks and mid-size SUV's . I have done this swap with my old trans am to uses a thicker rimmed 01-03 grand prix wheel . The upper shaft I used was from a 2005 w-body grand prix column. The threads to attach the wheel are smaller, but the lower portion of the shaft that mounts to the column is the exact same as the F-body shaft. It is a tedious bitch of a swap, the dissassemby and re-assembly is a nightmare . But it does work .
The airbag was NON functional and I unbolted the inflator from the back of it so it could never go off . I never have and dont advise trying to make a airbag from another car work, because theres no way to test it .
While I have not tried it, it is entirely possible the 06-current 3 spoke wheel everyone wants to run so bad will bolt right up to the W-body shaft in the years I listed . GM does not change these sizes very often .
