clear corners with no water or moisture problems?
Old Feb 13, 2004 | 12:37 AM
SSideExhLS1's Avatar
Default clear corners with no water or moisture problems?
i already bought two pairs from ebay, as soon as it rains or wash the car, they fill up with water. makes car look like crap. i have tried sealing them, and i know the bulbs are setting in correctly. if you dont have this problem, please tell me where you got yours and what brand, cost does not matter.
Old Feb 13, 2004 | 09:33 PM
joedrum71's Avatar
I drilled tiny holes in the bottom (2 or 3, can't remember). They've been on for 2 yrs., never had any problems. I haven't sealed them either.
Old Feb 13, 2004 | 11:31 PM
willis 00's Avatar
all you need to do is get some clear silcone rtv sealant and go around the edges. smooth it in the seams with your finger. they dont do a good job sealing them from the factory. anytime you buy aftermarket lights do this. if done right it will do the trick.
Old Feb 14, 2004 | 07:40 AM
unit213's Avatar
Administrator
I bought mine from afterthoughts auto and I never had a single drop of moisture in them.
Old Feb 14, 2004 | 04:24 PM
White94Z's Avatar
I have moisture in my left one right now, just to lazy to mess with it, i will wait till i start drive the car when the weather gets better, i might try the drillin the whole thing
Old Feb 15, 2004 | 12:21 AM
MarkH's Avatar
I have had my clear corners from Afterthoughts Auto for quite a while, around 2 years at least, and they have not had any leaking issues. None. It seems like 90% of the people who have them have problems though so I guess I am one of the lucky ones. Mine are also the clear diamond ones, not the clear stock looking ones but I don't know if that makes a difference.
Old Feb 15, 2004 | 12:57 AM
ritchie's Avatar
Last time I posted my solution, I got laughed at..... but here it goes. I've had mine for almost a year, off ebay. this is the link to the ones I bought:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2460162343
I installed my clears and ran my car to the car wash, and as soon as I was done rinsing the car off, the clears had water in them. I realized that the water is coming in from the TOP of the lens, where the bulb screws in (mine sat a little loose). Right above that area is where the bumper and bottom of the headlight meet, and there is a gap. If you stick your hand in that gap, you will feel the wire harness for the bulb to the turn signal. I went under the car and went over the the top part of the clear corner housing with tape, in all directions..... and guess what? PROBLEM SOLVED. I really don't think that you need to go around the edges with silicone, although it couldn't hurt. I didn't.
So, like I said, last time I got flamed for posting this but it worked for me. Good luck!
oh, yeah..... if you have something smartass to say......
Old Feb 15, 2004 | 07:49 AM
scalemaster's Avatar
what do u have to take off to do the install I have a set also and I need to install them but how
Old Feb 16, 2004 | 09:45 PM
1BadMoFo's Avatar
I've got a set coming from Ebay (different seller) and the faulkers better not leak!
Old Feb 16, 2004 | 09:50 PM
00SS4780's Avatar
A few tiny little holes here on the bottom. Mine never realy had alot of water going in but seemed to fog up alittle.
Old Feb 17, 2004 | 05:51 PM
Z28-CTYHNTR's Avatar
I dont know why people always have problems with thier clear corners. I bought those cheap ones from afterthought and been through 2 winters and summers with them with no problems or drill holes in them. Guess Im lucky eh?
Old Feb 17, 2004 | 07:04 PM
Nasty Hawk's Avatar
i bought mine from afterthoughts for my TA front pair no problems.. rear pair have been thru 2 sets already the chrome or mirror in the peels and flakes away, look like ****..
