3M Di-Noc Carbon
Either way, if you do it, get REAL Di-Noc. Not the cheap ****. The real stuff doesn't come in a glossy version. The 3M Di-Noc is supposed to be good for up to 5 years I think outdoors. If you do it though, make sure you get the 3M Tape Primer 94 to make sure the ends don't come up and finger.
Oh, and somewhere on here, a guy did the taillight filler panel on his Camaro in it. Didn't look half bad. Would have looked 10x better had he used 1 piece.
Pics on page 3, but read through all the comments.
http://www.gtoforum.com/f41/3m-carbon-fiber-wrap-26507/
This was mentioned, apparently it's better than the 3M:
http://cgi.ebay.com/ebaymotors/ws/eB...ht_2468wt_1008
Apparently, if you don't have a heat gun, there's no point in even attempting it. Maybe a hot blow dryer would help, but not sure. Overall everyone seems to think that it's a pain in the *** to work with, but there's definitely some pretty good results out there with the product, if you can work well with it.
Good luck!
Good luck!
Also, a heatgun isn't necessary. A simple hairdryer will more than suffice.
As far as the link goes, or what your talking about, I'm not really sure...The link doesn't work. True 3M Di-Noc only comes in the matte finish, so there isn't any gloss finish to be had. If its glossy, its not real Di-Noc. Just keep that in mind.
Radio Bezel
laptop
The color of the carbon is a lot lighter in the pictures. At certain angles in person it looks straight black.
I must have said it 3 times in this thread alone...3M TAPE PRIMER 94! That around the edges will help...Damn. Google is your friend...
At the very minimum I would scrub interior panels with dawn dish soap, then apply the adhesion promotor. I myself would scuff the surface with 400 sandpaper then wash , the promotor . Apply right and it should last.
