pics of 5pt harnesses in 4th gen
Old Mar 7, 2011 | 11:46 AM
Anniversary "Z"'s Avatar
Default pics of 5pt harnesses in 4th gen
Can some of you that have 5 point harnesses in your 4th gens post some pics?
Thinking my seats are not going to allow it and may have to just get 4 point harnesses, but thought I'd check here first.
If I replace my seats I want a stylish, fairly comfortable seat that accepts a 5pt.
any suggestions?
Old Mar 7, 2011 | 01:00 PM
ssteven's Avatar
Mine with 6le seats
Old Mar 7, 2011 | 01:09 PM
I actually emailed 6le this morning cause some of the pics on the website weren't working for me.
Your pics were exactly what I was looking for since my current seats didn't have a hole for the crotch strap I wasn't sure if they'd work. But my Sparco's look just like those!!
Thanks steven!!
PS I did some cruising around the site earlier and will probably be putting an order in there in the near future!!
Old Mar 7, 2011 | 02:47 PM
sempire's Avatar
Originally Posted by ssteven@6LE
Mine with 6le seats
That isn't a cage is it? Is it one of those harness bars?
Old Mar 7, 2011 | 03:11 PM
OIF1VET's Avatar
Old Mar 7, 2011 | 04:12 PM
badbird's Avatar
mine work fine with the stock TA seats.
id try to get some pics for ya but its in pieces again
Old Mar 7, 2011 | 04:52 PM
I know what ya mean. I keep tearing mine further and further apart and tell myself one day I'll open the garage a *poof* it'll be done!!
Thanks for the pics guys, I've been talking to one of our track officials and they say OEM-type seat is okay for crotch strap to go in front rather than through. I hope they like me passing my Sparco as OEM-typish
Old Mar 7, 2011 | 05:41 PM
badbird's Avatar
it never ends does it. i think ill have everything i need to start putting it back together in another week or two, just dont know where to even start the reassembly.
you should be fine (im assuming your talking about kcir). i dont think they ever looked at my harnesses at all. they normally just check the battery hold down and the bottle setup if i have it in the car.
Old Mar 7, 2011 | 07:33 PM
Big bird55's Avatar
were are you guys bolting the side and crotch straps. any pics ???
Old Mar 7, 2011 | 07:56 PM
Yeah plan on most of my passes to be at KCIR just all this talk abotu them being stricter about kicking people off this year has me a little leary of trying to slide things by. Most likely I'll be told to load and go home a couple times this year if I decide to run out the back door. Also, I think Jillian will be paying close attention since she knows the knew setup I have
Old Mar 7, 2011 | 07:57 PM
The sides usually bolt in the stock seatbelt holes and the crotch strap uses a bar. This is from what I've been told and seen. Open to hear other's opinions and what has worked for everyone else.
Old Mar 7, 2011 | 08:03 PM
badbird's Avatar
my harness came with brackets that bolt into the stock seat belt holes and then you either have to buy or make a bracket for the crotch strap that bolts on with the front two bolts for the seat.
your gonna have to pm me some details on the new setup. especially the intake. you went with a victor setup right? ive been thinking about switching mine over.
Old Mar 7, 2011 | 08:26 PM
munsterz28's Avatar
scat seats with g-force harnesses held by a 6litereater harness bar
Attached Thumbnails pics of 5pt harnesses in 4th gen-attachment-1.jpg   pics of 5pt harnesses in 4th gen-attachment.jpg
Old Mar 7, 2011 | 08:39 PM
Does their bar attach to the same place the front seat bolts to like badbird mentioned?
Old Mar 7, 2011 | 08:45 PM
munsterz28's Avatar
yes the harness bar uses the stock mounts for the REAR belts. the crotch strap i bought bars from wolfe that coexist with the seats and use the front 2 studs where the seat mounts.
Old Mar 7, 2011 | 09:12 PM
badbird's Avatar
i think their bar is for the shoulder straps. its like the center bar going across the main hoop of the cage
Old Mar 8, 2011 | 06:57 AM
EchoMirage's Avatar
that is the only way a crotch strap should be run. just flopping it over the front of the seat does nothing and is dangerous. the sub belt is supposed to stop you from sliding out from under the belts in a crash. with it flopped over the front, it does absolutely nothing and can pull the belts away from you, instead of against you. if you want to have a 5pt harness, get a 5pt seat.
Old Mar 8, 2011 | 09:40 AM
What seat is that in the pic? Curious with the factory seatbelt mount still attached.
Old Mar 8, 2011 | 10:13 AM
munsterz28's Avatar
x2 those look like nice seats.
Old Mar 8, 2011 | 12:32 PM
EchoMirage's Avatar
the old style arizen seats.
the factory guide isnt attached, but it was an option. for some reason i though i couldnt use the stock belts with the new seats, but you can. for now its zip tied to the seat. 6LE has a writeup on attaching stock brackets to the seat, but i havent done it yet. this style seat isnt made anymore, and a new style has replaced it. it is slide adjustable, tilt, lumbar adjustable, and leather.
6LE offers his version of this seat, its a near match. you can also find mad racing seats that are very similar.
