Led gauges
Old Mar 16, 2011 | 09:58 AM
2000z28ss's Avatar
Default Led gauges
Hey I have a 2000 z28 , my gauge lights are really dull, I want to get LED's. Would it be hard to do? Or just plug them in and go? Also, I want to do the light down in the heater area, and where I turn mt headlights on and off. Any help would be appreciated, thanks!
Old Mar 16, 2011 | 10:14 AM
ssteven's Avatar
http://6litereaterdesigns.com/forum/...p?topic=1077.0
Old Mar 16, 2011 | 11:53 AM
YURVIEW's Avatar
here is a list of the bulbs you will need to swap all your interior lights to LEDs. and yes they just plug in
https://ls1tech.com/forums/appearanc...-led-list.html
Old Mar 16, 2011 | 12:13 PM
99'CajunFirehawk157's Avatar
Thumbs up
YURVIEW: here is a list of the bulbs you will need to swap all your interior lights to LEDs. and yes they just plug in
Just like powder puff said , nothing to it...most likely your old bulbs have are dim and dusty...hardest part is getting the speedo cluster out around your steering wheel, I highly suggest dropping your steering column down a few inches (unbolt brackets holding to dash) if not you get to play Houdini and chance scratching the clear speedo lens too.
Old Mar 16, 2011 | 12:19 PM
ssteven's Avatar
Mine came out too easy. You remove the clear speedo cover first then the back section comes right out. Use a screwdriver to pop the release tabs on top and pull. Also unscrew the tilt bar and remove rear cover for a bit more room.
