A totally different Camaro Splitter
here are the pre pics, Ill keep it updated as it comes along.
what i plan to do is take one piece of cardboard and trace all the way around the vette splitter.
Then, im going to take another piece of cardboard and trace the outline of the camaro nose.
Using the cardboard temp-let of the vette splitter, im going to make some notch cuts out of it to line up with the camaro nose. I am most likely going to also have to thin the thickness of the splitter toward the wheel well. Im doing this because i want the side profile of the car to be flat on the bottom.
i really dont like how current splitters tend to angle up in the front. So this is going to take some work.
the hardest part is going to be making the fiberglass extensions to make the distance to the wheel well. the vette overhang is much shorter than the f body. since i have zero fiberglass experience, this should be interesting.
Ill keep you guys updated, its not going to happen immediately, so be patient.
The splitter is actually fiber glass. I think im going to use a fiberglass kit to extend the splitter, then, if i mold it in, ill prob take your advise and go with something that has some flex.
Im a total novice when it comes to this stuff though.
haha
