Replacing Carpet
Old Apr 10, 2011 | 10:50 PM
jpac716's Avatar
Exclamation Replacing Carpet
I was wondering what is involved in replacing all of the carpet including hatch area and also the headliner. Do i need a professional or just a weekend with some friends. Also what has to be removed to do this.
Old Apr 10, 2011 | 10:59 PM
Super-Bat's Avatar
Open door. Look at carpet. Everything on top of carpet, needs to be removed prior to carpet removal.
Seats, seat belts, center console, and most plastic panels needs to be removed/lifted up and or away.
Headliner is easy, open doors and hatch. Remove sail panels, remove A-panels (if you're a T-top... not sure what you gotta do with that), remove dome light and slide out the back.
Obviously, install is reverse of removal.
Can be done alone within a couple of hours. Easier with friends...maybe.
Old Apr 10, 2011 | 11:02 PM
ANTICOP RAM AIR's Avatar
if youre doing carpet and headliner... every single nut, bolt and piece of ANYTHING attached to the interior (except door panels and dash assy.) has to be removed. do the front, then the rear, then do the middle.. it is layered kind of... I have done this many many times.. hehe.. Its easy but kind of time consuming to make sure you dont break any of that cheap *** plastic **** called "fbody interior"...
Old Apr 19, 2011 | 05:35 PM
Letum's Avatar
This was the simplest and easiest piece of information I have ever read. Answered all my questions about my headliner. Lol, Thanks you two.
Old Apr 19, 2011 | 08:06 PM
mrrman's Avatar
carpet, headliner was simple to replace...almost plug and play as it is all preformed, roll out the carpet, cut the holes for cables,seats and thats it...
Old Apr 20, 2011 | 08:28 AM
RickyMartinZ28's Avatar
Buy quality carpet, or you'll have a major pain in the *** to deal with. That is all.
Old Apr 20, 2011 | 09:20 AM
aQuickLS1's Avatar
sweet. I was wondering the same thing, except in a reg cab truck. Wich I would assume would be easier.
