True LED taillights?
Old Nov 21, 2007 | 02:03 PM
The Black Pearl's Avatar
TheGr8Schlotzky those are really neat!! I really wanna do that!
Old Nov 21, 2007 | 08:11 PM
TheGr8Schlotzky's Avatar
Originally Posted by Brian2006
What's the point of the diode on there?
Two diodes actually. Without the diodes, it was impossible to light up just the two bars for the parking lights. One diode keeps the power from going to the brake light circuit when only the parking lights are on, and the other diode bypasses the resistor to make the two bars as bright as the rest of the tail light when the brakes or blinkers are activated.
Old Dec 29, 2007 | 02:16 AM
99'CajunFirehawk157's Avatar
Would love to see the "seam" where you cut the housings apart and then how you "sticthed" them back together? Pics would be killer, been wanting to do some t/a ones for the longest, even boguht a new spare set of lights. Heard the oven deal was a no go too.
PLMK-Thanks!!!
Old Dec 29, 2007 | 02:31 AM
Kage's Avatar
Cool
Originally Posted by GoFast908Z
ebay ones are ricey
x2 Like a mathafaka!!!!
Old Dec 29, 2007 | 02:53 PM
The backs are by no means "neat," but no one sees the backs anyway. You can see from the picture, that there was some modification required to the back of the tail light housing to fit it back on the lens. Some fairly large pieces were cut out, and the back of the housing ended up in two pieces, then reassembled with silicone. here is a picture from the back of the assembled finished product.
As a precaution to anyone that's considering doing this, without modification of the tail light lens itself, to remove the diffusing angles, without LED diffusers, there is currently no LEDs on the market that I am aware of that are bright enough to be seen in daytime through the stock lenses. If you'd notice the factory LED tail lights on cars, the lens is simply a translucent red lens with no diffusers. The diffusers very effectively ruin the beam of the LEDs, causing the light to be wasted inside the tail light, and making for dangerous brake lights in the daytime.
My tail lights, when standalone, were absolutely BLINDING. Once installed in the factory housings, at night they were very visible, but in the daylight, they were near impossible to see at all.
I have since removed my LED tail lights, and for my next project, I will be working with Luxeon LEDs as they are much brighter and give off beam patterns similar to that of an incandescent bulb, while still providing the benefits of LED light.
Old Dec 29, 2007 | 03:08 PM
Your pic no workee, could be an imagshack problem?
Old Dec 30, 2007 | 01:45 AM
it works for me? Maybe it was down for a period. If it's still not working for you I can host it via photobucket instead.
Old Jan 16, 2008 | 09:55 PM
Pic works now, any new updates? If you have researched leds tails, you will have heard of a company called "spaghetti engineering", they make them for older cars but not late model fbodys, they will do a custom set but the problem is getting inside the housings, after that, its $4-600 with sequentials too.
Old May 18, 2014 | 12:23 AM
dbest1197's Avatar
Default Custom Taillights
Hey do you think you could do me some custom taillights??? I want some LED ones but McLaren p1 style...very custom camaro look
Old May 18, 2014 | 11:51 PM
justin455's Avatar
Douchebag On The Tree
Thread from 10 years ago, last updated 6 years ago and the member hasn't been active in 2 years...probably not gonna happen.
Old May 19, 2014 | 04:35 PM
fbodyrs96's Avatar
yeah, sold his car and those lights last year.
Old May 26, 2014 | 07:41 PM
  #32
1FASTZ28's Avatar
I would love to have those tails on my Camaro. Maybe this would be a project 6LE would take on.
