Rear center piece install?
Old Feb 28, 2004 | 11:48 AM
BlkBrdWS6's Avatar
Default Rear center piece install?
I have a new plain black centerpiece (between the taillights) that I want to put in. How do I get the original center piece out and install the new one? What do I have to remove and all? Thanks a lot!
Old Feb 28, 2004 | 12:51 PM
XtinctHawk02's Avatar
You will "almost" remove the tailights. Just go into your trunk and pull the carpet back and un-do the plastic wing nuts that hold the tailight's in. After those are un-screwed pull your tailight out and the center piece just slides out. It's really easy. Once you pull the carpet back you will see what I mean.
Good luck!
My webshot's page shows the installed piece.
