Found the perfect spot for the AIR System....
Old Jul 6, 2011 | 12:07 PM
2000 TAWS6's Avatar
Default Found the perfect spot for the AIR System....
Just where GM had it designed to be.....
Jon
Old Jul 6, 2011 | 12:09 PM
ZexGX's Avatar
How about a pic of the engine bay after this appearance mod? lol.
Old Jul 6, 2011 | 12:16 PM
2000 TAWS6's Avatar
What a difference it makes. Re did the pcv system too, all new hoses.
Jon
Old Jul 6, 2011 | 12:28 PM
sokr915's Avatar
did your ses light go on?
Old Jul 6, 2011 | 12:32 PM
2000 TAWS6's Avatar
Yes, I believe every other cycle as I clear it with my Predator after it comes on. Getting it tuned out shortly.
But well worth it.
Jon
Old Jul 6, 2011 | 12:34 PM
ZexGX's Avatar
Looks good. Next up: move the TCS so it sits near the PCM, and do the wire mod/wire tucking?
If you were having oil consumption issues, you may also want to invest in a dual catch can setup, like a Saikou Michi (because they look pretty good). http://i40.photobucket.com/albums/e2...6/DSC01474.jpg
Old Jul 6, 2011 | 12:42 PM
2000 TAWS6's Avatar
Thanks!
Is there a sticky for the TCS mod? Wire mod/tucking?
That's a trick looking catch can set up, definitely in the future.
Jon
Old Jul 6, 2011 | 03:01 PM
TruBloodTransAm's Avatar
I removed mine when I installed my headers.
Old Jul 6, 2011 | 04:07 PM
black_sheep454's Avatar
They do seem to work better in a trash can
Old Jul 6, 2011 | 04:36 PM
NufNuffZ28's Avatar
Thanks!
Jon
http://www.facebook.com/media/set/?s...type=1&theater
Not the best picture, but it's all I could find. Our car has traction control.
What I did was pretty simple. I just unbolted the TCS module, unplugged it and then positioned the cables going to it behind the engine. Next I routed the one going to the TB to where it looked the best and routed it back to the TB.
The one thing you have to do is extend the wires. Since I already have the !wire mod done, I simply ran the wires for the TCS under the fender and then out with the factory wires behind the computer and plugged it up there. It works great and can not be seen at all unless you are REALLY looking for it.
The only thing holding mine back there are a few stratigic wire ties. Make sure it will still function correctly when position as the cables do move(at least the wire in the cable) to control the TB when TC is on...
Old Jul 6, 2011 | 07:38 PM
Irish350's Avatar
my saiko michi doesnt fit where its supposed to with their bracket, so im having to make my own... also i spent too much on AN fittings cause i had him (miguel i think his name is.. theyre in nm) do male an fittings instead of nipples for rubber hose..
but i think once it actually works itll be cool lol
Old Jul 6, 2011 | 07:47 PM
Wimimc's Avatar
i took the fuses for the AIR/EGR when i removed them both, been driving a few months now and no light has come on.
Old Jul 6, 2011 | 08:38 PM
2000 TAWS6's Avatar
I pulled the air fuse and relay, still get SES. Have to get the three codes deleted.
Jon
Old Jul 6, 2011 | 08:40 PM
2000 TAWS6's Avatar
Thanks, facebook link does not work, but I get the drift from your post. Will have a look at it.
Jon
