Relocating/hiding coil packs
Old Jul 22, 2011 | 09:21 AM
the dan's Avatar
Default Relocating/hiding coil packs
I know some people have moved them iff the valvecovers, but where to? How long is a safe length for the wires? Where did you put them and a picture?. I want to put them under my headers but I'm worried about heat
Old Jul 22, 2011 | 12:32 PM
LPE 403's Avatar
Most are re-located under the cowl. Kits are available through a few vendors (Thunder Racing for example)...Katech offers a re-positioned coil kit that locates the coils parallel to the ground but is still mounted to the valve cover - an aftermarket cover only.
Not sure what your situation is or which direction you prefer, but I have the Katech version (never installed) that can't be used for my application for sale if interested.
Old Jul 22, 2011 | 01:30 PM
blackbyrd's Avatar
custom made brackets and wires for me passenger side coil packs are where the ecm sets on the factory car which you can sort of see in this picture, and the driver side is under the plexiglass panel where the fuse boxes were located from the factory. but my whole car is pretty much custom at this point.
no problems but i eventually want to redo it, since my car only gets out when its pretty i think i want to relocate them laterally on the frame rail (under the ac canister for the passenger side, and under the box the brake lines go into on the driver side)
but that is quite a ways off and sorry for the dirty pic but its the only one i have at the moment
Old Jul 22, 2011 | 05:03 PM
OIF1VET's Avatar
Mine are under the cowl... Made the wires.. Been this way for years and never an issue..
Old Jul 22, 2011 | 06:08 PM
trans2000am's Avatar
mine are under the frame rail will post pics
Old Jul 22, 2011 | 06:18 PM
OIF1VET's Avatar
I may have to make this a winter project...
Old Jul 23, 2011 | 07:16 AM
Pony Exp.305's Avatar
That cool..Pixes?? I want to see
Old Jul 30, 2011 | 08:47 AM
the dan's Avatar
thanks guys
i have a little easier engine bay to work in because its a truck, but i have a pet peeve about wires and this is the first ls/efi i have played with. so pretty much you can mount them anywhere reasonble?
Old Jul 30, 2011 | 10:05 PM
cookba's Avatar
a lot of the FI guys put the coils on the frame rails. and i like that idea too. I have mine under the cowl, got the kit from CC Performance. Nice kit but i want something with shorter wires. I will probably go back to coils on valve covers like the new LS9 valve covers and coils. same idea as the LS1's but it looks cleaner.
Old Jul 30, 2011 | 11:27 PM
DopeFedZ's Avatar
Mine are on the frame rail.
Old Aug 5, 2011 | 09:11 PM
cookba's Avatar
how are the frame mounted coils? who makes them? how are they for space to work with in there? any issues with weather or debri?
