Cleaning inside engine bay
Old Mar 1, 2004 | 10:08 PM
UGotBeaT's Avatar
Default Cleaning inside engine bay
Well I have no motor in my engine bay and it looks pretty bad in their i have rust on my k member and near my battery and everything looks kinda liek **** .....o yeh its a 98 t/a. So what should I use to clean all this stuff?
Old Mar 2, 2004 | 09:46 AM
VoodooWS6's Avatar
Simple green concentrated, no water...Let it sit for about 1 hour. Run a plastic brissile brush after application then let it sit. Power wash the bay and it will look brand new!
Old Mar 2, 2004 | 01:18 PM
UGotBeaT's Avatar
where do you get that simple green stuff at and where do i spray on my k member and on my wheel wells??
Old Mar 2, 2004 | 01:30 PM
BIGBOS's Avatar
You can get it at any auto supply store, they should carry it, I just try to keep up with the dust every time I go and get gas, I'll take a rag or wet rag and go over the dirty spots, its a lot easier then letting it build up all the time......
Old Mar 2, 2004 | 01:48 PM
30th TA 0219's Avatar
www.por15.com
EVERYTHING you will need, if you're serious about cleaning it up, and making it purty!
Old Mar 2, 2004 | 02:43 PM
Brandon_TA's Avatar
I used to use Simple Green on my truck Engines... It used to eat away the paint... Anyone else have this problem? Im too scared to use it on my car...
Old Mar 2, 2004 | 03:58 PM
WhiteDeathLS1's Avatar
Simple Green is awesome and it smells great too.
Old Mar 2, 2004 | 04:17 PM
travisnd's Avatar
just use some elbow grease and rags!
Old Mar 2, 2004 | 05:51 PM
slow's Avatar
i have used simple green no problem. but i've never kept it on for an hour.
i would paint the K member, with a POR product. if i ever get my motor out of my car.
Ryan
Old Mar 3, 2004 | 12:58 AM
JackZ28's Avatar
You could also try CD2. That's what I use. It comes in two aerosol cans. The first is a cleaner/degreaser and the second is just to make it shine like new!
Old Mar 3, 2004 | 09:03 AM
VoodooWS6's Avatar
Never had any problems with simple green..If you are worried, just do a 50/50 mix. Where do you find that CD-2 stuff? Everyone one says its great!!!
BigBos...You clean the engine bay everytime you get gas? WOW..I might have to try that..Our fans seem to kick up a lot of stuff off the road!
