Not your typical eBay Switchback LEDs
Old Aug 30, 2011 | 06:35 PM
ZexGX's Avatar
Default Not your typical eBay Switchback LEDs
I bought a set of iJDMtoy.com's special "dual-color LED" switchbacks. They are special in that each SMD LED is capable of producing two separate colors. Whereas with the competitors LEDs, they have to have separate LED modules for each color. In theory, that means that a 60 LED dual-color LED bulb has twice the light output of a 60 LED single-LED-colors bulb (30 white + 30 amber).
Threw them on my friends C5 Z06 to compare to his JWMotoring switchback LEDs:
http://www.youtube.com/watch?v=Lvitp9wkC5s
I bought them for $50 shipped from this link:
http://cgi.ebay.com/ebaymotors/_W0QQ...ht_10669wt_925
I'm still working with an issue with them on my car. When the headlights are on, they are white, and when you hit the hazards or turn signals, it flashes white-yellowishwhite-white instead of white-amber-white. I am hoping that a different flasher module will fix this, and will be trying to purchase one eventually.
On my car, right now, it works like so:
Lights off:
Amber running, flashes amber-off.
Parking:
Parking w/fogs:
Amber running, flashes amber-white.
Headlights:
White running, flashes white-yellowishwhite.
Color temp is about 6000k white. I'll be buying some 6000k HID bulbs for my fogs soon to replace the 5000k it currently has.
Old Aug 30, 2011 | 07:40 PM
White94Bird's Avatar
nvm...seems nffty..
When you figure out what falsher to use you gotta let us know.
Old Aug 30, 2011 | 07:46 PM
bad_408_vert's Avatar
Nice!
I will follow on which flasher you get to make it work. You cant use The flasher that the c5z has? Or something similar ?
Old Aug 30, 2011 | 08:11 PM
onebadapple98's Avatar
I bought those switchbacks right before spring ,and have had no problems with them at all.
Old Aug 30, 2011 | 08:51 PM
YURVIEW's Avatar
Nice find. Gonna grab a set of these
Old Aug 31, 2011 | 03:57 PM
Cwillits505's Avatar
Sub'd for later...
Old Aug 31, 2011 | 07:22 PM
Swiat34's Avatar
Try a digital solid state flashed instead of the analog one. Then see if that works. Also depending on your car it may illuminate both filaments of the original bulb. That means you'll have to play with your wiring a little bit.
Old Aug 31, 2011 | 07:45 PM
ZexGX's Avatar
My car is the same car as your car, assuming you still have the Formula/V6. And yes, that digital flasher is what I will be going with. I have the Tridon EL12 "electronic" flashers right now.
Old Aug 31, 2011 | 07:52 PM
lemons12's Avatar
Nice find.. Would an ls1 have the same issue?
Does anyone know if at night from a distance you can see the amber lights with fogs and lows on? I have hids in both so they are very bright.I love the amber look, looks aggressive. But if you cant see it ill pick a set up. I woupd check myself but my car isn't running atm.
Old Aug 31, 2011 | 08:00 PM
ZexGX's Avatar
The engine has nothing to do with the headlight wiring harness or the flasher modules.
That's your answer.
I'll check tonight.
Old Aug 31, 2011 | 08:14 PM
lemons12's Avatar
Sorry.. I meant an original ls1 car.. I didn't know if v6 and ls1 wiring was different. Figured was the same just wanted to check.
Thanks for checking that!
Old Aug 31, 2011 | 08:46 PM
With my low beams on along with fogs on they are white,and flash white to amber with flasher on.I didnt see any amber unless flasher was on. .
Old Aug 31, 2011 | 09:29 PM
lemons12's Avatar
I was wondering with the stock amber bulbs. I don't want to with to switch backs if they are visible with all the lights on.
Old Aug 31, 2011 | 09:51 PM
mrrman's Avatar
marked
Old Sep 1, 2011 | 01:16 PM
ZexGX's Avatar
I just realized last night what you were asking. When the low beams are on, the switchbacks are 6000k white. Not amber. Regardless of the fog light setting...
Old Sep 1, 2011 | 03:07 PM
lemons12's Avatar
Ahh... I thought you had put regular bulbs back in.
I will check with someone that has the stock amber bulbs in.
Old Sep 1, 2011 | 06:10 PM
pancho toco loco's Avatar
Wow those are pretty neat. Gotta get clear corner lenses now lol
Old Sep 2, 2011 | 08:17 AM
Is the EL12 Falsherr working?
Old Sep 2, 2011 | 12:46 PM
ZexGX's Avatar
It works, but the opposite DRL LED dims/flickers a little when the turn signal is activated, which leads me to believe that the flasher module is at fault. Hence my wanting to replace the flashers.
Old Oct 21, 2011 | 07:01 AM
98MNBZ28's Avatar
any updates??
