Engine bay cleaning!
2nd pic just shows the wires better
After: Removed AC, Wire mod, Air!, Egr!, Lid, p&p TB, painted STB, filled in holes, moved all grounds except one so far
what do you think? the strut towers and bracing all around will be getting stripped and painted, as well as the ls6 inake getting a silver flake paint job. any other suggestions??
Oh, and paint the lower airbox bolts black too.
and check out SummitRacing.com for some alternative air filter re-oiling colors if you don't want the standard K&N Red.
those are jus some ideas
what radiator supports are you talking about? if its where those 2 ground wires are attached, then I had planned on painting that already
and would engine enamel be good for the valve covers?? those will be gloss black I'm thinking, and my ls6 intake will become a silver metallic flake
Engine enamel black & engine enamel clear is what I used for my valve covers. The engine enamel rattlecan paint is formulated to be heat/chemical resistant so leaks won't take the paint off easily. Once you paint the intake silver, the coil packs would look good in the same color.
IMO if u do the valve covers, i'd keep the entire setup a uniform color but thats jus my personal preference.
