wheel spacers
Old Apr 8, 2003 | 10:43 AM
notfastenough's Avatar
Default wheel spacers
i was wondering if anyone here has used this type of spacer
http://www.skulte.com/adapters.html
if so, how do you like them?
do they hold up to repeated abuse?
Also, where can i buy normal wheel spacers, like, 3/16 and 1/4 inch?
thanks
Old Apr 8, 2003 | 02:39 PM
Xsta Z 28's Avatar
Default Re: wheel spacers
Most Auto Parts stroes sell the 1/4" universal spacers. I have found 5/16". Once you exceed 1/4" by much you'll have to get new lug studs.
The best kind to find are the "Hub Centric" spacers. Usually have to custom order them though.
I have never dealt with the big adapters.
Old Apr 8, 2003 | 03:21 PM
2FAST4U's Avatar
Don't buy adapters. Lots of damage can happen like wear out hub, braking wheels and lugs, lots of my friends used then all had problems. Costing big money like wheel ripped of and big time body damage!
Old Apr 8, 2003 | 10:06 PM
are the hub centric spacers the ones that are like a circle, like the hub itself, and slids over all 5 lugs at the same time?
where can i order these?
thanks
Old Apr 9, 2003 | 09:06 AM
Xsta Z 28's Avatar
A hub centric spacer is built specifically for the car, and it fits tight to the "hub" of the axle, basically that "button" that sticks out in the center. There are also "hub & wheel centric" spacer, which are even better, since the wheel is centered on the hub again.
<img src="http://www.hrsprings.com/site/products/images/spacers2.jpg" alt=" - " />
H&R is about the only one I know that makes them.
Old Apr 9, 2003 | 09:33 AM
thanks a lot for the help, im just trying to figure out the best way to mount my oem ZO6's with a prokit the best way with out rubbing, and with out doing to much monkeying!!
By Brett Foote | 2026-06-04 05:00:17
